SOLVED Deleted share and dataset, but always displayed in W10 network
profwalken
have recently deleted 4 dataset and shares all seems to be clear in GUI but when I browse network shares from a W10 computer, all the folders are always displayed but unavailable.
What I forgot to make thoses folders to disappear in Windows network too ?
the 4 Dataset and shared folders with black cross are deleted on FN side
profwalken
Hi thanks Anodos,
what do you mean shares cached in the client ?
I've tried after SMB restart , after server reboot, no change.
IN SAMBA there's no more share existing for these old folders from deleted dataset. See below.
either , no more dataset
what else coulsd i check ?
Is there possible display of old shared folders stay restored on windows 10 side even they are no more existing on FN ?
Samuel Tai
Check Credential Manager on Windows for login credentials for those shares.
anodos
Sambassador
You can double-check what the server returns for share enumeration by running the command smbclient -L //127.0.0.1 -U <username>. Windows initially enumerates shares by connecting to a hidden IPC share (IPC$) and sending an "enumerate" remote procedure call (RPC) to the srvsvc RPC endpoint. Windows clients don't poll on this RPC endpoint and so the information may be cached (or there may be some other reason why windows continues to display it).
profwalken
command line returns this, with nothing related to visible shares from a windows pc, list below is up to date.
profwalken
is it a coincidence or not , since command line has been executed now Windows display the right folders shared.
Thanks Anodos for help.
