Delete old Tunables parameter
sasad000
My FreeNAS 9.10.2 installed to USB boot and set some parameter of Tunables. Now I updated to FreeNAS 11.2
So I enable the new feature "AutoTune" .
Maybe my old parameter and "AutoTune " get a crash as below picture and no network.. I try to delete the old parameter "kern.ipc.maxsockets " = 262144 also get crash. I need to rebuild the USB again.
Thank.
Chris Moore
Not a new feature and never suggested for normal use. Did you read the warning in the manual?
Chris Moore
sasad000
Yes, so I want to disable and clean all of the parameter "Generated by autotune "
when I try to delete some parameter it will make the server crash as the picture
You're probably best to restore a previous config before you made the change.
