MMrrTT
- Oct 11, 2023
Hello.
I have 2 disk mirror pool. One disk was offline after the reboot because of power cable problem. I put it online again and now I have not healthy pool because this disk is degraged.
I believe the disk condition is ok, but still I performed full scrub and now long s.m.a.r.t. test. But how to get rid of the degraded state? With "zpool replace" command or any other easy way?
root@TrueNAS[~]# smartctl -a /dev/sdb
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.1.55-production+truenas] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Ultrastar DC HC550
Device Model: WUH721818ALE6L4
Serial Number: 5DG7W4VJ
LU WWN Device Id: 5 000cca 2b9c3948a
Add. Product Id: 202211
Firmware Version: PCGAW660
User Capacity: 18,000,207,937,536 bytes [18.0 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database 7.3/5319
ATA Version is: ACS-4 published, ANSI INCITS 529-2018
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Nov 8 05:27:20 2023 PST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x80) Offline data collection activity
was never started.
Self-test execution status: ( 249) Self-test routine in progress...
90% of test remaining.
data collection: ( 101) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: (1911) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000b 100 100 001 Pre-fail Always - 0
2 Throughput_Performance 0x0005 148 148 054 Pre-fail Offline - 48
3 Spin_Up_Time 0x0007 083 083 001 Pre-fail Always - 347 (Average 343)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 26
5 Reallocated_Sector_Ct 0x0033 100 100 001 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 001 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 140 140 020 Pre-fail Offline - 15
9 Power_On_Hours 0x0012 099 099 000 Old_age Always - 9260
10 Spin_Retry_Count 0x0013 100 100 001 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 26
22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100
82 Unknown_Attribute 0x0022 100 100 000 Old_age Always - 255
184 End-to-End_Error 0x0033 100 100 097 Pre-fail Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 414
193 Load_Cycle_Count 0x0012 100 100 000 Old_age Always - 414
194 Temperature_Celsius 0x0002 057 057 000 Old_age Always - 37 (Min/Max 16/54)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 100 100 000 Old_age Always - 0
241 Total_LBAs_Written 0x0012 100 100 000 Old_age Always - 29095913930
242 Total_LBAs_Read 0x0012 100 100 000 Old_age Always - 220335601709
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
