Degraded Pool / Need to convert from stripe to mirror
svtkobra7
I have a perplexing issue where a ZPool Status Report / SMART Report show everything to be OK and then a few hours later I see read / write errors. Considering the SMART report showed the drive was OK, I tried to replace the disk with the same one, but it gave an error because an existing partition was found. Upon that erring, I tried to force it, but that didn't work. I ran a zpool detach which converted that mirror to a stripe. I ran a scrub and rebooted, now I need to figure out:
  • Does that drive really have errors, and
  • How to convert that stripe to a mirror
I've tried to be as prescriptive as possible with providing information below. Thanks for your help.
1. Volume Status: Prior to Issue
  • Tank1
    • mirror-2
      • da11p1 / da9p1
    • mirror-1
      • da6p1 / da4p1
    • mirror-0
      • da3p1 / da2p1
2. Volume Status: Scrub in Progress / Pre-Reboot
  • Tank1
    • stripe
      • da11p1
    • mirror-1
      • da6p1 / da4p1
    • mirror-0
      • da3p1 / da2p1
3. Volume Status: Post-Scrub / Post-Reboot
  • Tank1
    • stripe
      • da10p1
    • mirror-1
      • da6p1 / da4p1
    • mirror-0
      • da3p1 / da2p1
Timeline of Events (Prior to Taking Any Action)
  • Monday @ 12:00 AM - ZPool Status Report
    • No Read / Write Errors
  • Monday @ 12:00 AM - SMART Status Report
    • No errors logged
  • Monday @ 3:29 AM - Tank1 Degraded
    • "The volume Tank1 state is DEGRADED: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state."
    • Read / Write Errors Shown in GUI
Action Taken
  • ZPool Status Confirms "DEGRADED" - See attached ZPool Status 1.txt
  • zpool detach Tank1 9422221597572091878
  • Initiated Scrub
  • ZPool Status Confirms "ONLINE" - See attached ZPool Status 2.txt
  • ZPool Status 1.txt
  • ZPool Status 2.txt
What a weird rendering bug:
Firefox on the left, Edge on the right.
Nope, 100%. Took me a week to get used to it some three years ago. Also happens when the window is shrunk down to mobile resolutions.
Stux
Not with the webGUI, but he could create the mirror via the command line. He'd need to search the forums for the commands.
zpool attach right?
gpsguy
Active Member
Yes, but one needs to run a few other commands first.
There are several threads on the topic on the forum. It took a bit of searching to find the one I remembered - https://forums.freenas.org/index.ph...ol-to-change-existing-stripe-to-mirror.26326/
zpool attach right?
@svtkobra7 do you have an environment where you can test this? Like a VM, etc. I'd backup any critical data data first, since backing up and rebuilding your pool correctly like @m0nkey_ said is also an option.
