I have a perplexing issue where a ZPool Status Report / SMART Report show everything to be OK and then a few hours later I see read / write errors. Considering the SMART report showed the drive was OK, I tried to replace the disk with the same one, but it gave an error because an existing partition was found. Upon that erring, I tried to force it, but that didn't work. I ran a zpool detach which converted that mirror to a stripe. I ran a scrub and rebooted, now I need to figure out:
1. Volume Status: Prior to Issue
3. Volume Status: Post-Scrub / Post-Reboot
Timeline of Events (Prior to Taking Any Action)
- Does that drive really have errors, and
- How to convert that stripe to a mirror
- Tank1
- mirror-2
- da11p1 / da9p1
- mirror-1
- da6p1 / da4p1
- mirror-0
- da3p1 / da2p1
- mirror-2
- Monday @ 12:00 AM - ZPool Status Report
- Monday @ 12:00 AM - SMART Status Report
- Monday @ 3:29 AM - Tank1 Degraded
- "The volume Tank1 state is DEGRADED: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state."
- Read / Write Errors Shown in GUI
- ZPool Status Confirms "DEGRADED" - See attached ZPool Status 1.txt
- zpool detach Tank1 9422221597572091878
- Initiated Scrub
- ZPool Status Confirms "ONLINE" - See attached ZPool Status 2.txt
