ChrisReeve
- Feb 21, 2019
I was trying to install a new RAID card to have all drives on HBAs instead of using the internal SATA ports (I did this for virtualization purposes)
But I forgot to export the pool, and when I booted back up, two drives weren't showing up, and the pool had degraded status. I eventually got all drives to show up, but the two drives that didnt show up earlier, are listed as UNUSED, and not a part of the pool.
What is the best way to proceed? Should I rebuild, knowing that I have no redundancy whatsoever during the rebuild, then export the pool, and make sure all drives show up in freeNAS before I import them again?
Or is there something else I can do to get the drives back in the pool without doing a full rebuild?
The pool is a 10x10TB WD Red in an encrypted ZFS2 pool.
The rest of the specs are as follows:
MB: Supermicro X9SRL-F
CPU: E5-2650 v2
RAM: 128GB 1600MHz ECC DDR3
HBAs: 2x LSI 9211-8i in IT mode
Cache drive: Intel DC P3700
NIC: Intel X540-T2
CPU: E5-2650 v2
NIC: Intel X540-T2
