Hi All,
Got back in last Saturday to find Truenas warning me that the pool was in a degraded state. On closer inspection 2 of the four disks had been removed. Que panic mode whilst I frantically made sure I had a backup of the data.
Whilst that was on going I got onto ordering some replacement drives. I've ended up with 2x 10Tb WD Gold. They came with a 5y warranty and were cheaper than any of the Red or Red Pro drives.
After backing up the data I replaced the failed drives and hit replace. Pool status seems ok.
Issues/Questions:
From the Syslog I see the following:
The other shows no such error. Is it possible that this was incorrectly kicked out? The drives were bought back in 2015 so I'm thinking replacement is probably a good idea anyway. Just unsure if I should be trusting any data to the drive.
In good news looks like resilver works just fine in TrueNAS-12.0-BETA2.1!
System is as follows currently:
OS: TrueNAS-12.0-BETA2.1
HP Microserver Gen 8
CPU: Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz
MEM: 16GB (2x8GB ECC)
OS Drive: 1x Intel® SSD 530 120GB
Storage: 2x 4TB WD Red, 2x 10TB WD Gold
RAID: ZFS RaidZ2
NET: Chelsio T320, 2 ports (10GB single DAC link)
Issues/Questions:
- I haven't burnt the drives in or checked them beyond running a quick SMART test from the GUI. I've hit "Manual S.M.A.R.T. Test" and "long" for each of the drives, will this be enough or should I do a more comprehensive test and if so how should I approach this? Offline drives individually and then test?
- I noticed the WD Gold uses significantly more power than the WD Red it replaced (spec says 10W). Would four drives be too much for the Microserver Gen 8 PSU (specs in sig)
- Smartctl -P show /dev/ada1 gives the following, I've never seen this before. Is it just that the model isn't in the database?
root@freenas[~]# smartctl -P show /dev/ada2 smartctl 7.1 2019-12-30 r5022 [FreeBSD 12.1-STABLE amd64] (local build) Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org No presets are defined for this drive. Its identity strings: MODEL: WDC WD102KRYZ-01A5AB0 FIRMWARE: 01.01H01 do not match any of the known regular expressions. Use -P showall to list all known regular expressions.
- Of the two drives that were booted out of the array one has the following:
Error 1 occurred at disk power-on lifetime: 25303 hours (1054 days + 7 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 10 51 08 90 01 40 e0 Error: IDNF at LBA = 0x00400190 = 4194704 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- ca 00 08 90 01 40 e0 00 09:09:41.315 WRITE DMA
Sep 12 15:43:59 freenas (ada3:ata3:0:1:0): RES: 51 10 c0 d2 97 20 20 01 00 08 00 Sep 12 15:43:59 freenas (ada3:ata3:0:1:0): Retrying command, 3 more tries remain Sep 12 15:46:17 freenas (ada3:ata3:0:1:0): WRITE_DMA48. ACB: 35 00 f8 0f 43 40 78 00 00 00 08 00 Sep 12 15:46:17 freenas (ada3:ata3:0:1:0): CAM status: ATA Status Error Sep 12 15:46:17 freenas (ada3:ata3:0:1:0): ATA status: 51 (DRDY SERV ERR), error: 10 (IDNF ) Sep 12 15:46:17 freenas (ada3:ata3:0:1:0): RES: 51 10 f8 0f 43 78 78 00 00 08 00 Sep 12 15:46:17 freenas (ada3:ata3:0:1:0): Retrying command, 3 more tries remain Sep 12 15:47:18 freenas (ada3:ata3:0:1:0): FLUSHCACHE48. ACB: ea 00 00 00 00 40 00 00 00 00 00 00 Sep 12 15:47:18 freenas (ada3:ata3:0:1:0): CAM status: Command timeout Sep 12 15:47:18 freenas (ada3:ata3:0:1:0): Retrying command, 0 more tries remain Sep 12 15:47:18 freenas ada2 at ata3 bus 0 scbus1 target 0 lun 0 Sep 12 15:47:18 freenas ada2: <WDC WD40EFRX-68WT0N0 82.00A82> s/n WD-WCC4E3LHE7R4 detached Sep 12 15:47:18 freenas ada3 at ata3 bus 0 scbus1 target 1 lun 0 Sep 12 15:47:18 freenas ada3: <WDC WD40EFRX-68WT0N0 82.00A82> s/n WD-WCC4E7TZH262 detached Sep 12 15:47:18 freenas GEOM_MIRROR: Device swap0: provider ada2p1 disconnected. Sep 12 15:47:18 freenas GEOM_MIRROR: Device swap0: provider ada3p1 disconnected. Sep 12 15:47:18 freenas g_access(961): provider gptid/f0df517c-65c7-11e9-89d2-000f53160620 has error 6 set Sep 12 15:47:18 freenas g_access(961): provider ada3 has error 6 set Sep 12 15:47:18 freenas g_access(961): provider ada2 has error 6 set Sep 12 15:47:18 freenas (ada3:ata3:0:1:0): Periph destroyed Sep 12 15:47:18 freenas (ada2:ata3:0:0:0): Periph destroyed Sep 12 15:47:23 freenas 1 2020-09-12T15:47:23.872590+00:00 freenas.ransome-pearce savecore 9116 - - /dev/ada1p1: Operation not permitted Sep 12 15:47:25 freenas syslog-ng[9221]: syslog-ng starting up; version='3.25.1' Sep 12 15:47:25 freenas GEOM_ELI: Device mirror/swap0.eli destroyed. Sep 12 15:47:25 freenas GEOM_MIRROR: Device swap0: provider destroyed. Sep 12 15:47:25 freenas GEOM_MIRROR: Device swap0 destroyed. Sep 12 15:47:25 freenas kernel: pid 1200 (syslog-ng), jid 0, uid 0: exited on signal 6 (core dumped) Sep 12 15:47:25 freenas GEOM_ELI: Device ada1p1.eli created. Sep 12 15:47:25 freenas GEOM_ELI: Encryption: AES-XTS 128 Sep 12 15:47:25 freenas GEOM_ELI: Crypto: hardware Sep 12 15:47:27 freenas 1 2020-09-12T15:47:27.842730+00:00 freenas.ransome-pearce savecore 9264 - - /dev/ada1p1: Operation not permitted
RAID: ZFS RaidZ2
