Decision Criteria for Processor Type
Schifty1
Hi Guys,
My Home Server died, and I’m thinking of building a FreeNAS system and need some advice about the hardware base I should use. The work load is light to medium.
I looked at the Resource page, and most of the hardware there is a couple of years old or later, so I decided to see what new hardware is available.
It turns out that ASRock has a miniITX board that uses the new C246 chips (Board Model C246 WSi). I currently have a call into their Tech Sales department to see when one will be available. It supports 64GB RAM (2 slots), and 8 SATA 3 connections. Cost should be in the $200 dollar range.
It uses either the E-2100 series XEON processors, or a variety of i5/7 core processors. The processors have graphics built in, so that’s an easy.
The question is if the XEON and the i5/7 cost roughly the same, what is the next decision criteria? Both types have 4 cores, 8 MB of cache and run in the 3.5GHz range. Specifically, I’m looking at the:
  • Xeon E-2104G, 8 MB Cache, 3.2 GHz Freq. Cost ~$195 (65 Watts)
  • Xeon E-2126G, 12 MB Cache, 3.3 GHz Freq.. Cost ~$250 (80 Watts)
  • I7 8700, 12 MB Cache, 3.2 GHz Freq. Cost ~ $300 (65 Watts)
  • I5 8600, 9 MB Cache, 3.1 GHz Freq. Cost ~ $250 (65 Watts)
  • I5 8500T, 9 MB Cache, 2.1 GHz Freq. Cost ~ $220 (Low PWR version, ~ 35 Watts)
Any help making this decision is greatly appreciated.
Thanks in advance for your comments/suggestions.
I haven't heard of anyone managing to actually buy one of the newer boards from any vendor.
Xeons support ECC, i5s and i7s don't. It's that simple and that is why the latter don't make sense.
That's a four-core/four-thread part. It probably isn't worth the extra cash over an i3-8xxx.
Six-core part, still no hyperthreading, for some reason. It's probably overkill for "light to medium" workload, but you'd have to be more specific.
Schifty1
HI Ericloewe,
Thanks for the quick reply and explanation. I missed the no ECC support in the i5/i7's.
As a result of your comments, I generated the attached spread sheet compiled from the Intel Website detailing XEON's separated by Graphics support with Hyperthreading and ECC. I included some "suggested" pricing as ball park numbers.
I hope this helps others converge on interesting processors for their application.
Regards
  • XEON Feature List.xlsx
Careful, you've got quite the eclectic mixture of parts there. You have LGA1151 in both Xeon E3 v5/v6 / C23x and Xeon E / C24x variants (they're artificially incompatible and will not work with the other), Xeon-D (soldered BGA) and LGAHoly-crap-so-many-pins.
