The key words here are "Feature Flags" which can make or break compatibility between different ZFS implementations. TrueNAS 12 will be merging with the regular OpenZFS branch so it
should support most everything - but have a look at the resource here that explains things and enumerates what's available in the different revisions.
OpenZFS' distributed development led to the introduction of Feature Flags. Instead of incrementing version numbers, support for OpenZFS features is indicated by Feature Flags. Feature Flag states Feature flags exist in one of three states...
www.ixsystems.com
You might encounter some other oddities such as TrueNAS being confused about where to put its system dataset and swap files - some manual massaging might be required afterwards - but I would expect the pool itself to import without much complaint if you haven't used some bleeding-edge feature on Debian.
