De nouveau un problème de perte de disque ???
Pitfrr
Does the HBA show up in the console (in dmesg)?
There are also some commands like:
sas2ircu list to list the controlers
or
sas2flash -list to check the HBA interface
And I think there are other commands to check if the card is seen by TrueNAS but I don't recall right now....
profwalken
I need to check this :wink:
Cables are Supermicro CBL-0294-02 REV 1.00
profwalken
Pitfrr
At least the card is seen by TrueNAS.
The only differences I see with my card are:
Adapter type: SAS2008
Firmware version: 20.00.07.00
I think I recall there was something with the firmware version.... but I don't remember exactly... :-(
Do you see the disk in dmesg?
profwalken
Voilà le résultat de dmesg, j'ai pas l'impression qu'il y ait quelquechose. Pour le firmware different tu sais si c'est simple à mettre à jour car là je ne sais pas ou télécharger la P20 et comment faire la maj.
Copyright (c) 1992-2021 The FreeBSD Project.
Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
        The Regents of the University of California. All rights reserved.
FreeBSD is a registered trademark of The FreeBSD Foundation.
FreeBSD 13.1-RELEASE-p1 n245406-814eb095751 TRUENAS amd64
FreeBSD clang version 13.0.0 (git@github.com:llvm/llvm-project.git llvmorg-13.0.        0-0-gd7b669b3a303)
VT(vga): text 80x25
CPU: Intel(R) Xeon(R) CPU E3-1246 v3 @ 3.50GHz (3492.14-MHz K8-class CPU)
  Origin="GenuineIntel"  Id=0x306c3  Family=0x6  Model=0x3c  Stepping=3
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,C        MOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x7ffafbff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,SD        BG,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,        OSXSAVE,AVX,F16C,RDRAND>
  AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
  AMD Features2=0x21<LAHF,ABM>
  Structured Extended Features=0x27ab<FSGSBASE,TSCADJ,BMI1,AVX2,SMEP,BMI2,ERMS,I        NVPCID,NFPUSG>
  XSAVE Features=0x1<XSAVEOPT>
  VT-x: (disabled in BIOS) PAT,HLT,MTF,PAUSE,EPT,UG,VPID
  TSC: P-state invariant, performance statistics
real memory  = 34359738368 (32768 MB)
avail memory = 33092706304 (31559 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <HPQOEM SLIC-WKS>
FreeBSD/SMP: Multiprocessor System Detected: 8 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s) x 2 hardware threads
random: registering fast source Intel Secure Key RNG
random: fast provider: "Intel Secure Key RNG"
random: unblocking device.
ioapic0 <Version 2.0> irqs 0-23
Launching APs: 1 6 5 2 7 4 3
random: entropy device external interface
kbd1 at kbdmux0
vtvga0: <VT VGA driver>
aesni0: <AES-CBC,AES-CCM,AES-GCM,AES-ICM,AES-XTS>
padlock0: No ACE support.
acpi0: <HPQOEM SLIC-WKS>
acpi0: Power Button (fixed)
cpu0: <ACPI CPU> on acpi0
hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
Timecounter "HPET" frequency 14318180 Hz quality 950
Event timer "HPET" frequency 14318180 Hz quality 550
atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0
atrtc0: Warning: Couldn't map I/O.
atrtc0: registered as a time-of-day clock, resolution 1.000000s
Event timer "RTC" frequency 32768 Hz quality 0
attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
vgapci0: <VGA-compatible display> port 0xe000-0xe07f mem 0xee000000-0xeeffffff,0        xd0000000-0xdfffffff,0xe0000000-0xe1ffffff irq 16 at device 0.0 on pci1
vgapci0: Boot video device
pci1: <multimedia, HDA> at device 0.1 (no driver attached)
xhci0: <Intel Lynx Point USB 3.0 controller> mem 0xef520000-0xef52ffff irq 16 at        device 20.0 on pci0
xhci0: 32 bytes context size, 64-bit DMA
xhci0: Port routing mask set to 0xffffffff
usbus0 on xhci0
usbus0: 5.0Gbps Super Speed USB v3.0
pci0: <simple comms> at device 22.0 (no driver attached)
uart2: <Intel Lynx Point KT Controller> port 0xf0a0-0xf0a7 mem 0xef53a000-0xef53        afff irq 19 at device 22.3 on pci0
uart2: Using 1 MSI message
em0: <Intel(R) I217-LM LPT> port 0xf040-0xf05f mem 0xef500000-0xef51ffff,0xef539        000-0xef539fff irq 20 at device 25.0 on pci0
em0: EEPROM V0.13-4
em0: Using 1024 TX descriptors and 1024 RX descriptors
em0: Using an MSI interrupt
em0: Ethernet address: 50:65:f3:39:aa:d0
ehci0: <Intel Lynx Point USB 2.0 controller USB-B> mem 0xef538000-0xef5383ff irq        16 at device 26.0 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci0
usbus1: 480Mbps High Speed USB v2.0
pci0: <multimedia, HDA> at device 27.0 (no driver attached)
pcib2: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0
pci2: <ACPI PCI bus> on pcib2
mps0: <Avago Technologies (LSI) SAS2004> port 0xd000-0xd0ff mem 0xef4c0000-0xef4        c3fff,0xef480000-0xef4bffff irq 16 at device 0.0 on pci2
mps0: Firmware: 17.00.01.00, Driver: 21.02.00.00-fbsd
mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,Even        tReplay,HostDisc>
pcib3: <ACPI PCI-PCI bridge> irq 17 at device 28.1 on pci0
pci3: <ACPI PCI bus> on pcib3
igb0: <Intel(R) I210 (Copper)> mem 0xef200000-0xef2fffff,0xef300000-0xef303fff i        rq 17 at device 0.0 on pci3
igb0: EEPROM V3.16-0 Option ROM V1-b304-p0 eTrack 0x800004ff
igb0: Using 1024 TX descriptors and 1024 RX descriptors
igb0: Using 4 RX queues 4 TX queues
igb0: Using MSI-X interrupts with 5 vectors
igb0: Ethernet address: a0:36:9f:85:ee:20
pcib4: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0
pci4: <ACPI PCI bus> on pcib4
pcib5: <ACPI PCI-PCI bridge> irq 19 at device 0.0 on pci4
pci5: <ACPI PCI bus> on pcib5
ehci1: <Intel Lynx Point USB 2.0 controller USB-A> mem 0xef537000-0xef5373ff irq        23 at device 29.0 on pci0
usbus2: EHCI version 1.0
usbus2 on ehci1
usbus2: 480Mbps High Speed USB v2.0
isab0: <PCI-ISA bridge> at device 31.0 on pci0
isa0: <ISA bus> on isab0
ahci0: <Intel Lynx Point AHCI SATA controller> port 0xf090-0xf097,0xf080-0xf083,        0xf070-0xf077,0xf060-0xf063,0xf020-0xf03f mem 0xef536000-0xef5367ff irq 19 at de        vice 31.2 on pci0
ahci0: AHCI v1.30 with 5 6Gbps ports, Port Multiplier not supported
ahcich0: <AHCI channel> at channel 0 on ahci0
ahcich1: <AHCI channel> at channel 1 on ahci0
ahcich2: <AHCI channel> at channel 2 on ahci0
ahcich5: <AHCI channel> at channel 5 on ahci0
ahciem0: <AHCI enclosure management bridge> on ahci0
acpi_button0: <Power Button> on acpi0
acpi_tz0: <Thermal Zone> on acpi0
acpi_tz1: <Thermal Zone> on acpi0
atkbdc0: <Keyboard controller (i8042)> port 0x60,0x64 irq 1 on acpi0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
driver bug: Unable to set devclass (class: atkbdc devname: (unknown))
ichwd0: <Intel Lynx Point watchdog timer> on isa0
orm0: <ISA Option ROMs> at iomem 0xc0000-0xce7ff,0xce800-0xcefff,0xcf000-0xcffff        ,0xd0000-0xd0fff pnpid ORM0000 on isa0
coretemp0: <CPU On-Die Thermal Sensors> on cpu0
est0: <Enhanced SpeedStep Frequency Control> on cpu0
Timecounter "TSC-low" frequency 1745956867 Hz quality 1000
Timecounters tick every 1.000 msec
ZFS filesystem version: 5
ZFS storage pool version: features support (5000)
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, loggi        ng disabled
ugen1.1: <Intel EHCI root HUB> at usbus1
ugen0.1: <Intel XHCI root HUB> at usbus0
ugen2.1: <Intel EHCI root HUB> at usbus2
uhub0 on usbus1
uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
uhub1 on usbus0
uhub1: <Intel XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
uhub2 on usbus2
uhub2: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2
Trying to mount root from zfs:boot-pool/ROOT/default []...
ses0 at ahciem0 bus 0 scbus5 target 0 lun 0
ses0: <AHCI SGPIO Enclosure 2.00 0001> SEMB S-E-S 2.00 device
ses0: SEMB SES Device
ada0 at ahcich0 bus 0 scbus1 target 0 lun 0
ada0: <V Series SATA SSD 120GB V4.15.0> ACS-3 ATA SATA 3.x device
ada0: Serial Number 213910663702800
ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 512bytes)
ada0: Command Queueing enabled
ada0: 114473MB (234441648 512 byte sectors)
ses0: pass0,ada0 in 'Slot 00', SATA Slot: scbus1 target 0
ada1 at ahcich1 bus 0 scbus2 target 0 lun 0
ada1: <V Series SATA SSD 120GB V4.15.0> ACS-3 ATA SATA 3.x device
ada1: Serial Number 213910663704535
ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 512bytes)
ada1: Command Queueing enabled
ada1: 114473MB (234441648 512 byte sectors)
ada2 at ahcich5 bus 0 scbus4 target 0 lun 0
ada2: <ST2000VN004-2E4164 SC60> ACS-2 ATA SATA 3.x device
ada2: Serial Number Z52BWQRK
ada2: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes)
ada2: Command Queueing enabled
ada2: 1907729MB (3907029168 512 byte sectors)
ses0: pass1,ada1 in 'Slot 01', SATA Slot: scbus2 target 0
ses0: pass2,cd0 in 'Slot 02', SATA Slot: scbus3 target 0
ses0: pass3,ada2 in 'Slot 05', SATA Slot: scbus4 target 0
cd0 at ahcich2 bus 0 scbus3 target 0 lun 0
cd0: <hp DVD A  DS8ACSH LHS3> Removable CD-ROM SCSI device
cd0: Serial Number 426537900560
cd0: 150.000MB/s transfers (SATA 1.x, UDMA6, ATAPI 12bytes, PIO 8192bytes)
cd0: Attempt to query device size failed: NOT READY, Medium not present - tray c        losed
uhub1: 21 ports with 21 removable, self powered
Root mount waiting for: usbus0 usbus1 usbus2
uhub2: 3 ports with 3 removable, self powered
uhub0: 3 ports with 3 removable, self powered
ugen0.2: <Lite-On Technology Corp. Lenovo USB Keyboard> at usbus0
ukbd0 on uhub1
ukbd0: <Lite-On Technology Corp. Lenovo USB Keyboard, class 0/0, rev 1.10/1.13,        addr 1> on usbus0
kbd2 at ukbd0
uhid0 on uhub1
uhid0: <Lite-On Technology Corp. Lenovo USB Keyboard, class 0/0, rev 1.10/1.13,        addr 1> on usbus0
ugen0.3: <Logitech USB-PS/2 Optical Mouse> at usbus0
ums0 on uhub1
ums0: <Logitech USB-PS/2 Optical Mouse, class 0/0, rev 2.00/25.00, addr 2> on us        bus0
ums0: 4 buttons and [XYZ] coordinates ID=0
ugen2.2: <vendor 0x8087 product 0x8000> at usbus2
uhub3 on uhub2
uhub3: <vendor 0x8087 product 0x8000, class 9/0, rev 2.00/0.05, addr 2> on usbus        2
ugen1.2: <vendor 0x8087 product 0x8008> at usbus1
uhub4 on uhub0
uhub4: <vendor 0x8087 product 0x8008, class 9/0, rev 2.00/0.05, addr 2> on usbus        1
uhub4: 6 ports with 6 removable, self powered
uhub3: 8 ports with 8 removable, self powered
ugen0.4: <Realtek USB3.0 Card Reader> at usbus0
umass0 on uhub1
umass0: <Bulk-In, Bulk-Out, Interface> on usbus0
umass0:  SCSI over Bulk-Only; quirks = 0x4000
umass0:6:0: Attached to scbus6
(probe0:umass-sim0:0:0:0): REPORT LUNS. CDB: a0 00 00 00 00 00 00 00 00 10 00 00
(probe0:umass-sim0:0:0:0): CAM status: SCSI Status Error
(probe0:umass-sim0:0:0:0): SCSI status: Check Condition
(probe0:umass-sim0:0:0:0): SCSI sense: ILLEGAL REQUEST asc:24,0 (Invalid field i        n CDB)
(probe0:umass-sim0:0:0:0): Error 22, Unretryable error
da0 at umass-sim0 bus 0 scbus6 target 0 lun 0
da0: <Generic- USB3.0 CRW-CF/MD 1.00> Removable Direct Access SPC-4 SCSI device
da0: Serial Number 201312261010
da0: 400.000MB/s transfers
da0: Attempt to query device size failed: NOT READY, Medium not present
da0: quirks=0x2<NO_6_BYTE>
da1 at umass-sim0 bus 0 scbus6 target 0 lun 1
da1: <Generic- USB3.0 CRW-SD 1.00> Removable Direct Access SPC-4 SCSI device
da1: Serial Number 201312261010
da1: 400.000MB/s transfers
da1: Attempt to query device size failed: NOT READY, Medium not present
da1: quirks=0x2<NO_6_BYTE>
da2 at umass-sim0 bus 0 scbus6 target 0 lun 2
da2: <Generic- USB3.0 CRW-MS 1.00> Removable Direct Access SPC-4 SCSI device
da2: Serial Number 201312261010
da2: 400.000MB/s transfers
da2: Attempt to query device size failed: NOT READY, Medium not present
da2: quirks=0x2<NO_6_BYTE>
ichsmb0: <Intel Lynx Point SMBus controller> port 0xf000-0xf01f mem 0xef535000-0        xef5350ff irq 18 at device 31.3 on pci0
smbus0: <System Management Bus> on ichsmb0
lo0: link state changed to UP
vmx_modinit: VMX operation disabled by BIOS
module_register_init: MOD_LOAD (vmm, 0xffffffff83604200, 0) error 6
igb0: link state changed to UP
debugnet_any_ifnet_update: Bad dn_init result from igb0 (ifp 0xfffff80005204800)        , ignoring.
GEOM_MIRROR: Device mirror/swap0 launched (2/2).
GEOM_ELI: Device mirror/swap0.eli created.
GEOM_ELI: Encryption: AES-XTS 128
GEOM_ELI:     Crypto: accelerated software
CPU: Intel(R) Xeon(R) CPU E3-1246 v3 @ 3.50GHz (3491.91-MHz K8-class CPU)
  Structured Extended Features3=0x9c000600<MCUOPT,MD_CLEAR,IBPB,STIBP,L1DFL,SSBD        >
igb0: link state changed to DOWN
hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<IN        T,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI>
Security policy loaded: MAC/ntpd (mac_ntpd)
arp: 43:05:43:05:00:00 is multicast
profwalken
Vidéo du boot avec message de la carte LSI qui ne voit pas de disque supporté. (il n'y a qu'un disque connecté sur la carte lsi, cest un WD Red)
Redcoat
Those cables appear to be reverse breakout, not forward breakout, from my searching.
Also, please check the part number you gave - I cannot find it on Supermicro's US site.
profwalken
Well that's a good news, thanks for your finding Red, right on target, probably the problem is only in those cables, I will ask my provider for cable change, for now have no other to test with
profwalken
Well , provider is sending me replacement cables CBL-0237L for free, just need to wait . Part coming from Denmark to France.
in between I will update to latest firmware P20 from a windows pc as i don't even know if it's possible directly from Freebsd.
profwalken
@Redcoat on which website did you found cables ? prices are low it cost me 40€ for same part
Redcoat
Pitfrr
mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,Even tReplay,HostDisc> pcib3: <ACPI PCI-PCI bridge> irq 17 at device 28.1 on pci0
D'après dmesg le système "voit" bien la carte.
Et il y a trois disques, ada0, ada1 qui sont les SSD de 120Go et ada2, un disque seagate de 2To.
Et en da0, da1 et da2 tu as des périphériques USB mais je ne vois pas très bien ce que c'est... des boitiers de disques externes peut-être?
profwalken
ada0 et ada1 sont les 2 SSD et ada2 c'est un futur disque de données mais ces 3 disques sont connectés sur les ports SATA de la carte mère pas sur la carte LSI, le seul disque connecté dessus n'est pas visible. je vai tenter le flashage en P20 depuis mon pc Windows ( Ca je maitrise mieux)
j'attends les nouveaux cables CBL-0237L que va me fournir le vendeur.
profwalken
I succeeded in updating the board, so now it's up to date in P20 release, I just ordered now on Amazon, the cable that Red pasted a link for me. So with prime, it should be delivered fast. I received also today the last missing disk so now it's just a cable problem to wait for.
profwalken
you're right I made a typo missing L in model reference
profwalken
Hi all,
today i received from Amazon the right cables and tryied with and tadaaaa.. disks are seen without any problem:smile:
Big Thanks you @Pitfrr and @Redcoat , your advices where right on target and problem is fixed.
Hope one day i'll be able to help someone like you both do
Pitfrr
Glad to hear that it worked!
Enjoy...
Redcoat
Very glad here also :smile:
