Data for UPS stale
BUT:
Problem after following the guide mentioned. Getting emails:
Cron <root@nas> /bin/sh /usr/local/sbin/save_rrds.sh
rm: /data/rrd_dir.tar.bz2: Read-only file systemmv: rename rrd_dir.tar.bz2.28209 to /data/rrd_dir.tar.bz2: Read-only file system
and
mv: rename rrd_dir.tar.bz2.26710 to /data/rrd_dir.tar.bz2: Read-only file system
and so on.
Probably mount -uw and mount -ur broke something.
EDIT: I think this might be caused by omitting the '/' in the commands?
mount -uw /
echo "MAXAGE 25">>/etc/local/nut/upsd.conf
mount -ur /
Just don know how to solve this....
Created a separate thread here
Got an answer, from the thread mentioned above:
If you're on 9.3, do not use the mount commands shown in older guides. The boot filesystem changed in 9.3 and it is no longer mounted r/o.
So we should only use:
without the mount commands.
This won't survive a reboot
