dashboard not working after upgrade
Jeremy Guo
Hi, all
I upgraded my truescale from 22.12.3 to 22.12.4 then upgrade it to 23.10.1.3, now the dashboard is hung, always flashing with truenas logo.
it was working when I finish upgrade to 22.12.4, but not working after the second upgrade.
any suggestion?
thanks
Jeremy
Jeremy Guo
reporting are also not working.
any troubleshooting suggestions?
LarsR
Did you try the usual stuff? E.g. clear browser cache, a different browser or a force refresh with shift+f5? Sometimes after an update, especially after a major version jumb, the gui can try to load old cached browser data and then gets stuck.
Jeremy Guo
thanks. buddy.
I tried edge and google browser, cleared cache, no luck.
Jeremy Guo
will a clean installation fix this? will the DB backup restore the storage back to it's configuration before installation?
