Dashboard for TrueNas Enterprise says FreeNAS
kappclark
Running TrueNAS Enterprise. The Dashboard in upper left says FreeNAS, and also the graphic in the System Information Tile.
Is this normal ?
Kris Moore
SVP of Engineering
Administrator
Nope. Try a shift-F5 to force a refresh of the UI or clear cache? Also, is your enterprise license key installed?
kappclark
THX - FWIW The Bronze support contract expired 5-18-2021 -- Also tried refresh - same result ... everything seems to be running properly ..
Kris Moore
SVP of Engineering
Administrator
Interesting, it does sound cosmetic only, however we'd like to take a look at that. Can you do an update to 12.0-U5.1 at some point and confirm the logo is still wrong? If so, please open a ticket with a debug attached on jira.ixsystems.com and we'll take a look into why this is occurring. In the meantime, maybe try another browser / system just to rule out 100% its a local cache issue?
kappclark
Chrome and Edge - they both sign in and the initial Dashboard screen screen shows TrueNas, then it changes to FreeNAS ..
We are running 12.0-U4, and see the updates available -- will need to do after hours... will let the community know ...
kappclark
Did the update to 12.0-U5.1 and rebooted -- same issue
Patrick M. Hausen
Are you sure nobody set the "retro logo" option for nostalgic reasons?
kappclark
Patrick -- that did it ! the setting was turned on... turned off and now it shows Truenas ... thx for the reply --- Mark This SOLVED!
kappclark
I know this sounds silly, but make sure that no one is expecting it to say "FreeNAS" and will get confused by it saying the new name. :wink:
Done !
