Alex9779
- Nov 23, 2012
Hi community,
yesterday I replaced a defective hard drive with some corrupt sectors in my pool. Then resilvering started but before I already had 5 permanent errors in the status of the pool, all <metadata>:. Now after the process completed I scrubbed the pool which repaired 2 error but none of the 5 above.
I tracked to problem down to a specific dataset. When I try to delete that dataset or specific snapshots in it my kernel crashes with "Fatal trap 12" and so on...
Maybe another device I defect in my pool and I think I know which one it is because of its smart stats although smart does not report any defect sectors.
I ran another short scrub and somehow 3 of the 5 permanent error vanished.
Heres a current output of "zfs status -v Storage":
What can I do now? I am not able to delete the defect dataset, always the kernel crashes.
Shall I replace the perhaps defect device too, resilver and then try again? Maybe it crashes because it cannot access the specific areas of that disk.
Please help, Oracle help is not very helpful here, I don't find anything about this situation, only if the pool reports defect metadata AND is not importable but mine is...
Regards,
Alexander
pool: Storage state: ONLINE status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: http://www.sun.com/msg/ZFS-8000-8A scan: scrub canceled on Sun Mar 17 17:19:50 2013 config: NAME STATE READ WRITE CKSUM Storage ONLINE 0 0 0 raidz1-0 ONLINE 0 0 0 gptid/076c01a1-6501-11e1-b9bd-f46d04d898d3 ONLINE 0 0 0 gptid/24d575f3-8e96-11e2-91f9-f46d04d898d3 ONLINE 0 0 0 gptid/0870c326-6501-11e1-b9bd-f46d04d898d3 ONLINE 0 0 0 gptid/08ddeb79-6501-11e1-b9bd-f46d04d898d3 ONLINE 0 0 0 gptid/094e2ef1-6501-11e1-b9bd-f46d04d898d3 ONLINE 0 0 0 errors: Permanent errors have been detected in the following files: <metadata>:<0x226e4e> <metadata>:<0x2267be>
Regards,
Alexander
