Cron jobs screen fields not persistent, should be
sfatula
So, am using the cron jobs screen found via system settings -> advanced and clicking on the icon next to "cron jobs" to open up the list. On that screen, you can set what fields you want to show. I turn off for example users and command by using the drop down columns menu. It shows perfectly as expected. I do something else on any other screen, come back to the ron jobs screen, and, users and command are re-enabled and I have to do it again. Every single time.
Should those field selections be persistent? I notice that doing the same to init/shutdown scripts results in persistent fields.
