mrbryo
- Oct 18, 2013
I searched as much as I could in the forum and couldn't find the answer and I double checked the manual to make sure I didn't miss any steps.
Not sure you need it but here is my system info:
Hostname freenas.southpark
Build FreeNAS-9.1.1-RELEASE-x64 (a752d35)
Platform Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
Memory 4075MB
System Time Fri Oct 18 16:41:06 PDT 2013
Uptime 4:41PM up 2 days, 21:40, 1 user
Load Average 0.08, 0.03, 0.01
Connected through 192.168.1.54
I have two cron jobs setup however I don't think they are running. They are setup as root. I should probably set them up as a different user (my unix skills are subpar, i can move around the directory structure and change permissions, enough to be dangerous).
I found one post that shows the crontab here: /etc/crontab, but doesn't list the jobs I added.
I also found another post that shows logs here: /var/log
I checked the file cron by grep-ing for 'btsync' which is part of the command line but nothing. Then I decided to grep all the files for 'btsync' and got this:
dmesg.today:WARNING pid 4219 (btsync): ioctl sign-extension ioctl ffffffff8004667e
messages:Oct 15 19:04:18 freenas kernel: WARNING pid 4219 (btsync): ioctl sign-extension ioctl ffffffff8004667e
What I can gather from google searches it has to do with maybe a bug in the program. I've run it manually with the same command line as root and it starts up just fine. Warnings don't typically mean the program failed to start. So still haven't found anything to tell me why the jobs are not running. Maybe they are I just can't find the err logs for btsync.
Not sure where to go from here other than adding entries to the crontab on my own. Some posts in the forum indicate any changes will be overwritten since it is rebuilt from DB entries.
Some background of the jobs. I want to run BitTorrent Sync during the day and night but during the day I don't want it to use all my bandwidth so I run a different configuration file. One job kills btsync and starts it with the day time config and the second one kills btsync and start it with the night time config.
Thanks for taking the time to read and any help is appreciated.
Brian
Memory 4075MB
Brian
