Critical - Unrecoverable Error
NAS-Plus
I received an error message on one of our FreeNAS servers. The error says:
CRITICAL: May 30, 2017, 1:36 a.m. - The volume vol_xx (ZFS) state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
The only additional information that I can see is under Volume Status / Scrub. One of the 4 raidz1 drives has a Checksum value of 33. The other 3 drives all show a Checksum value of 0. All 4 of the drives show 0 Read, 0 Write, and show a Status of Online.
How serious is this? Do I need to replace the drive with Chicksum of 33? Is there anything else that I need to do?
Thanks,
Jailer
Not strong, but bad
Do a smart test to the drive that shows errors and post in quotes, please.
Code tags please so the formatting doesn't get all wonky.
NAS-Plus
Thanks! Will do.
I started the following check:
smartctl -t long /dev/da1
It says that it will take 355 minutes to complete.
NAS-Plus
I'm still new to FreeNAS so if I did this incorrectly don't hesitate to tell me.
The da1p2 drive is the one that now has 39 in the checksum column. All the other drives have 0 in the columns.
I extracted the SMART data with the following command: smartctl -a /dev/da1 | more
Extended self-test routine
recommended polling time:  ( 355) minutes.
Conveyance self-test routine
recommended polling time:  (  5) minutes.
SCT capabilities:  (0x3035) SCT Status supported.
  SCT Data Table supported.
ID# ATTRIBUTE_NAME  FLAG  VALUE WORST THRESH TYPE  UPDATED  WHEN_
FAILED RAW_VALUE
  1 Raw_Read_Error_Rate  0x002f  200  200  051  Pre-fail  Always  -
  0
  3 Spin_Up_Time  0x0027  189  172  021  Pre-fail  Always  -
  5541
  4 Start_Stop_Count  0x0032  100  100  000  Old_age  Always  -
  61
  5 Reallocated_Sector_Ct  0x0033  200  200  140  Pre-fail  Always  -
  0
  7 Seek_Error_Rate  0x002e  200  200  000  Old_age  Always  -
  0
  9 Power_On_Hours  0x0032  063  063  000  Old_age  Always  -
  27403
 10 Spin_Retry_Count  0x0032  100  253  000  Old_age  Always  -
  0
 11 Calibration_Retry_Count 0x0032  100  253  000  Old_age  Always  -
  0
 12 Power_Cycle_Count  0x0032  100  100  000  Old_age  Always  -
  59
192 Power-Off_Retract_Count 0x0032  200  200  000  Old_age  Always  -
  68
193 Load_Cycle_Count  0x0032  001  001  000  Old_age  Always  -
  1357642
194 Temperature_Celsius  0x0022  120  108  000  Old_age  Always  -
  30
196 Reallocated_Event_Count 0x0032  200  200  000  Old_age  Always  -
  0
197 Current_Pending_Sector  0x0032  200  200  000  Old_age  Always  -
  0
198 Offline_Uncorrectable  0x0030  200  200  000  Old_age  Offline  -
  0
199 UDMA_CRC_Error_Count  0x0032  200  200  000  Old_age  Always  -
  13
200 Multi_Zone_Error_Rate  0x0008  200  200  000  Old_age  Offline  -
SMART Error Log Version: 1
No Errors Logged
  0
  0
  0
  13
No Errors Logged
Num  Test_Description  Status  Remaining  LifeTime(hours)  LBA
_of_first_error
# 1  Extended offline  Completed without error  00%  27400  -
# 2  Short offline  Completed without error  00%  27385  -
# 3  Short offline  Completed without error  00%  27361  -
# 4  Short offline  Completed without error  00%  27337  -
# 5  Extended offline  Completed without error  00%  27298  -
# 6  Short offline  Completed without error  00%  27266  -
# 7  Short offline  Completed without error  00%  27241  -
# 8  Short offline  Completed without error  00%  27217  -
# 9  Short offline  Completed without error  00%  27193  -
#10  Short offline  Completed without error  00%  27169  -
#11  Extended offline  Completed without error  00%  27126  -
#12  Short offline  Completed without error  00%  27099  -
#13  Short offline  Completed without error  00%  27075  -
#14  Short offline  Completed without error  00%  27053  -
#15  Short offline  Completed without error  00%  27027  -
#16  Short offline  Completed without error  00%  27002  -
#17  Extended offline  Completed without error  00%  26971  -
#18  Short offline  Completed without error  00%  26930  -
#19  Short offline  Completed without error  00%  26906  -
#20  Short offline  Completed without error  00%  26882  -
#21  Short offline  Completed without error  00%  26859  -
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay
SweetAndLow
Sweet'NASty
Not the problem but load cycles are through the roof. What kind of drive is this? You need to use wdidle on it.
NAS-Plus
Here is the drive information:
Model Family:	 Western Digital Caviar Green (AF)
Device Model:	 WDC WD20EARS-00MVWB0
Serial Number:	WD-WCAZA1349441
LU WWN Device Id: 5 0014ee 20503e92b
Firmware Version: 51.0AB51
User Capacity:	2,000,398,934,016 bytes [2.00 TB]
Sector Size:	  512 bytes logical/physical
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:	Thu Jun  1 01:29:17 2017 CDT
SMART support is: Enabled
SMART Status not supported: Incomplete response, ATA output registers missing
Warning: This result is based on an Attribute check.
SweetAndLow
Sweet'NASty
Read up on wdidle and green drives. You should do it to all of them.
