ecatanzani
- Feb 4, 2018
Hi to everyone, I'm new to the forum and I'm here to share a problem hoping in a solution.
I have a freeness server with the following specs:
- Intel(R) Xeon(R) CPU X3450 @ 2.67GHz
- Supermicro X8SIL as MOBO
- 16 G DDR3 ECC ram
I installed freeness 11.1 and I'm wondering to create a new Linux virtual machine for simulation purposes. I know the hardware is not great, but better than my MacBook Pro ;-)
So, I created a zvol, created the vm and added the iso and zvol to it as devices.
The problem is that, when I run the vm, it will automatically stops and I have no way to proceed with the OS installation.
On then as monitor is written:
I checked on the bios and VT-d is on.
May you help me with that problem ?
Thanks a lot.
Regards
- 16 G DDR3 ECC ram
tap0: Ethernet adders: 00:bd:8b:ad:0d:00 bridge0: can't disable some capabilities on em0: 0x1
Thanks a lot.
Regards
