Crashplan tunnel not working
alexthefourth
After several hours of tinkering with the crashplan plugin I finally got it to stay on. Now my problem seems to be that the tunnel between my pc and the crashplan jail is not being made. I would like to know how i can verify that?
I can ssh into the jail, i have changed the ui file to change the port on my pc to 4200.
One problem i have is that i cannot check the top of sockstat -4 to see this line:
[root@freenas] ~# jexec crashplan_1 sockstat -4
USER COMMAND PID FD PROTO LOCAL ADDRESS FOREIGN ADDRESS
crashplan sshd 4149 5 tcp4 192.168.1.103:22 192.168.1.83:53226
root sshd 4147 5 tcp4 192.168.1.103:22 192.168.1.83:53226
root java 3952 56 tcp4 127.0.0.1:4243 *:*
root java 3952 57 tcp4 *:4242 *:*
root java 3951 56 tcp4 127.0.0.1:4243 *:*
when i run sockstat -4 it runs and goes to the bottom so i cannot see the first line. is there a way to view the top line of sockstat -4?
fracai
You can pipe the result through "less".
As in:
jexec crashplan_1 sockstat -4 | less
Use the arrow keys to scroll up or down and press 'q' when you're done.
alexthefourth
thank you
so when i run that I do not see this line
but if i run cpuset -l 0 /usr/local/share/crashplan/bin/CrashPlanEngine status it shows that it is running.
im not sure how to troubleshoot this or how to start sshd under the crashplan user.
qwerion
Use a different port than 4200. That one no longer works for some reason. Using 42000 personally.
If you care to check, the ui.log of the crashplan client has the error message:
invalid core port specified! - 4200 defaulting to 4243
