David3D
 - Sep 10, 2013
EDIT:  See edits below!
I can't for the life of me get CrashPlan to talk to the GUI on my Windows 7 x64 desktop.
I've followed every tutorial, some do it differently to others, but everything seems to be correct. The longer setup with SSH is not a requirement for me, even though less secure.
I've unhashed serviceHost=192.168.1.2 (and added IP as you can see) within ui.properties under C:\Users\USER\AppData\Local\Programs\CrashPlan\conf
Note: This path is NOT in Program Files, which makes me think that perhaps this is part of the issue. However, this is where CrashPlan decided to install.
I've changed the my.service.xml document under crashplan_1/usr/pbi/crashplan-amd64/share/crashplan/conf with "0.0.0.0" from "127.0.0.1".
CrashPlan did launch successfully without modified files however. Shall I uninstall and simply not launch until I've modified the required files? Does it matter that I launched it first in 4.5?
Sockstat reads as follows, which I believe is correct.
I've tried varying jail settings with regards to checking and unchecking NAT, VIMAGE. I havn't changed autostart. I've tried making changes with jail on and off. I've tried making changes to CrashPlan plugin files via the jail console and FTP. I've tried making the changes with the plugin on and off. I've restarted the plugin after making changes.
I've disabled my Windows firewall and antivirus (Avast Business) but to no avail.
I'm hoping there is something very simple I'm over-looking, but short of something wrong with my local install, firewall or router, I'm a bit stuck.
If anyone has any ideas, they'd be much appreciated.
EDIT1: Switched from 4.5.2 to 3.6.3 and from 64 bit versions of each to the 32 bit versions which ended up installing in Program files(x86) and I'm still having an issue connecting. :(
EDIT2: Re-installed and rebooted both machines and it now gives me an option to log in, but refuses my account details telling me they are incorrect. The "forgot password" details link to a different website "crashplan.com" rather than "code42.com/crashplan", so apparently 4.52 and 3.6.3 are operating off of different databases. Perhaps it is because when I selected a CrashPlan account, I selected "CrashPlan PRO For Small Business" and my account is separate to "home users".
I created a rubbish account through the GUI and it works fine.
I seem to have configured the jail storage incorrectly however, but I'll sort that on another day.
Glad I have it working. I now have to contact CrashPlan and get them to cancel my trial on the email address I actually want to use. Either that, or somehow update the crashplan plugin within the jail to 4.5.2. my technical skills do not go that far though!
I hope these findings are useful for someone else if they have a problem with their account.
Cheers,
David
USER COMMAND PID FD PROTO LOCAL ADDRESS FOREIGN ADDRESS root java 33230 59 tcp4 *:4243 *:* root java 33230 60 tcp4 *:4242 *:* root java 33197 59 tcp4 *:4243 *:* root java 33197 60 tcp4 *:4242 *:* root java 33196 59 tcp4 *:4243 *:* root java 33196 60 tcp4 *:4242 *:* root java 33195 59 tcp4 *:4243 *:* root java 33195 60 tcp4 *:4242 *:* root java 33194 59 tcp4 *:4243 *:* root java 33194 60 tcp4 *:4242 *:* root java 33193 59 tcp4 *:4243 *:* root java 33193 60 tcp4 *:4242 *:* root java 33192 59 tcp4 *:4243 *:* root java 33192 60 tcp4 *:4242 *:* root java 33191 59 tcp4 *:4243 *:* root java 33191 60 tcp4 *:4242 *:* root java 33190 59 tcp4 *:4243 *:* root java 33190 60 tcp4 *:4242 *:* root java 33189 59 tcp4 *:4243 *:* root java 33189 60 tcp4 *:4242 *:* root java 33188 59 tcp4 *:4243 *:* root java 33188 60 tcp4 *:4242 *:* root java 33187 59 tcp4 *:4243 *:* root java 33187 60 tcp4 *:4242 *:* root java 33186 59 tcp4 *:4243 *:* root java 33186 60 tcp4 *:4242 *:* root java 33185 59 tcp4 *:4243 *:* root java 33185 60 tcp4 *:4242 *:* root java 33184 59 tcp4 *:4243 *:* root java 33184 60 tcp4 *:4242 *:* root java 33183 59 tcp4 *:4243 *:* root java 33183 60 tcp4 *:4242 *:* root java 33182 59 tcp4 *:4243 *:* root java 33182 60 tcp4 *:4242 *:* root java 33181 59 tcp4 *:4243 *:* root java 33181 60 tcp4 *:4242 *:* root java 33180 59 tcp4 *:4243 *:* root java 33180 60 tcp4 *:4242 *:* root java 33179 59 tcp4 *:4243 *:* root java 33179 60 tcp4 *:4242 *:* root java 33178 59 tcp4 *:4243 *:* root java 33178 60 tcp4 *:4242 *:* root java 33177 59 tcp4 *:4243 *:* root java 33177 60 tcp4 *:4242 *:* root java 33176 59 tcp4 *:4243 *:* root java 33176 60 tcp4 *:4242 *:* root java 33175 59 tcp4 *:4243 *:* root java 33175 60 tcp4 *:4242 *:* root java 33174 59 tcp4 *:4243 *:* root java 33174 60 tcp4 *:4242 *:* root java 33173 59 tcp4 *:4243 *:* root java 33173 60 tcp4 *:4242 *:* root java 33172 59 tcp4 *:4243 *:* root java 33172 60 tcp4 *:4242 *:* root java 33171 59 tcp4 *:4243 *:* root java 33171 60 tcp4 *:4242 *:* root java 32995 59 tcp4 *:4243 *:* root java 32995 60 tcp4 *:4242 *:* root java 32994 59 tcp4 *:4243 *:* root java 32994 60 tcp4 *:4242 *:* root java 32993 59 tcp4 *:4243 *:* root java 32993 60 tcp4 *:4242 *:* root java 32992 59 tcp4 *:4243 *:* root java 32992 60 tcp4 *:4242 *:* root java 32991 59 tcp4 *:4243 *:* root java 32991 60 tcp4 *:4242 *:* root java 32990 59 tcp4 *:4243 *:* root java 32990 60 tcp4 *:4242 *:* root java 32989 59 tcp4 *:4243 *:* root java 32989 60 tcp4 *:4242 *:* root java 32988 59 tcp4 *:4243 *:* root java 32988 60 tcp4 *:4242 *:* root java 32987 59 tcp4 *:4243 *:* root java 32987 60 tcp4 *:4242 *:* root python2.7 13523 3 tcp4 192.168.1.2:12348 *:* root syslogd 12076 7 udp4 *:514 *:*
Cheers,
David
