I noticed some issues with the CrashPlan plugin in FreeNAS 9.10. I installed the CrashPlan plugin, but it wasn't working. I got "ELF unknown type" errors when trying to start it. These came out even when invoking "java -version" manually.
I tracked down the problem to a missing Linux kernel module in FreeNAS. kldstat shows:
[root@freenas] ~# kldstat
Id Refs Address Size Name
1 83 0xffffffff80200000 17dd000 kernel
2 1 0xffffffff81cae000 fdd44 ispfw.ko
3 1 0xffffffff82011000 f934 geom_mirror.ko
4 1 0xffffffff82021000 4694 geom_stripe.ko
5 1 0xffffffff82026000 ffb1 geom_raid3.ko
6 1 0xffffffff82036000 ec6a geom_raid5.ko
7 1 0xffffffff82045000 573b geom_gate.ko
8 1 0xffffffff8204b000 4a26 geom_multipath.ko
9 1 0xffffffff82050000 895 dtraceall.ko
10 10 0xffffffff82051000 3ad02 dtrace.ko
11 1 0xffffffff8208c000 463a dtmalloc.ko
12 1 0xffffffff82091000 224a dtnfscl.ko
13 1 0xffffffff82094000 63d7 fbt.ko
14 1 0xffffffff8209b000 580fb fasttrap.ko
15 1 0xffffffff820f4000 49cb lockstat.ko
16 1 0xffffffff820f9000 15ec sdt.ko
17 1 0xffffffff820fb000 d8d7 systrace.ko
18 1 0xffffffff82109000 d486 systrace_freebsd32.ko
19 1 0xffffffff82117000 4d94 profile.ko
20 1 0xffffffff8211c000 7fe3 ipmi.ko
21 1 0xffffffff82124000 1a62f hwpmc.ko
22 2 0xffffffff8213f000 2b32 vboxnetflt.ko
23 2 0xffffffff82142000 45370 vboxdrv.ko
24 1 0xffffffff82188000 41c2 ng_ether.ko
25 1 0xffffffff8218d000 3fd4 vboxnetadp.ko
26 1 0xffffffff82191000 9fc3 linprocfs.ko
27 2 0xffffffff8219b000 66e1 linux_common.ko
Running "kldload linux" loads the linux module and allows CrashPlan and other Linux binaries to work again. When I reboot FreeNAS, the linux module is not loaded again.
Is this a known issue? Has anyone else hit this? Should I open a bug?
