Not sure if posted in correct section, but anyone offer any advice on mounting a dvdrom within freenas to read data from the disc.
This what I have tried so far using the shell
mount -t cd9660 /dev/cd0 /media/dvdrom it looks as though it has mounted, but when you look at the folder there is a readme.txt, which when you open it, it shows the following
i then entered 'kldstat' which shows udf.ko installed, which should allow the reading of optical media.edit /etc/devfs.conf
uncommented the following line and saved the file
#link cd0 dvd
edit /edit/fstab
added the following line and saved this, but on reboot it is removed (also tried with udf instead of iso9660)
/dev/cd0 /media/cdrom0 iso9660 ro,user,noauto 0 0
the command 'camcontrol devlist' reportsId Refs Address Size Name
1 79 0xffffffff80200000 14d7000 kernel
2 1 0xffffffff8199b000 1781de ispfw.ko
3 1 0xffffffff81c12000 485f geom_stripe.ko
4 1 0xffffffff81c17000 10481 geom_raid3.ko
5 1 0xffffffff81c28000 102dd geom_raid5.ko
6 1 0xffffffff81c39000 57fe geom_gate.ko
7 1 0xffffffff81c3f000 49b4 geom_multipath.ko
8 1 0xffffffff81c44000 b12 dtraceall.ko
9 1 0xffffffff81c45000 4ea5 profile.ko
10 3 0xffffffff81c4a000 356b cyclic.ko
11 10 0xffffffff81c4e000 3448b dtrace.ko
12 1 0xffffffff81c83000 fef5 systrace_freebsd32.ko
13 1 0xffffffff81c93000 10bd9 systrace.ko
14 1 0xffffffff81ca4000 4a9b sdt.ko
15 1 0xffffffff81ca9000 48e9 lockstat.ko
16 1 0xffffffff81cae000 b56d fasttrap.ko
17 1 0xffffffff81cba000 6661 fbt.ko
18 1 0xffffffff81cc1000 556e dtnfscl.ko
19 1 0xffffffff81cc7000 4575 dtmalloc.ko
20 1 0xffffffff81ccc000 87a6 ipmi.ko
21 1 0xffffffff81cd5000 3321a if_cxgbe.ko
22 2 0xffffffff81d09000 2bb1 vboxnetflt.ko
23 2 0xffffffff81d0c000 46f6c vboxdrv.ko
24 1 0xffffffff81d53000 4472 ng_ether.ko
25 1 0xffffffff81d58000 400a vboxnetadp.ko
26 1 0xffffffff81d5d000 8e37 udf.ko
entering 'file -s /dev/cd0' displays<WDC WD30EFRX-68EUZN0 80.00A80> at scbus0 target 0 lun 0 (ada0,pass0)
<WDC WD30EFRX-68EUZN0 80.00A80> at scbus1 target 0 lun 0 (ada1,pass1)
<WDC WD20EARS-00MVWB0 51.0AB51> at scbus2 target 0 lun 0 (ada2,pass2)
<WDC WD20EARS-00MVWB0 51.0AB51> at scbus3 target 0 lun 0 (ada3,pass3)
<ST3320620AS 3.AAE> at scbus4 target 0 lun 0 (ada4,pass4)
<HL-DT-ST BDDVDRW GGC-H20L 1.03> at scbus5 target 0 lun 0 (cd0,pass5)
<Kingston DataTraveler 2.0 1.00> at scbus7 target 0 lun 0 (da0,pass6)
entering 'ls -al /dev/cd*' displays/dev/cd0: # ISO 9660 CD-ROM filesystem data 'GRMCHPXFRER_EN_DVD ' (bootable)
if i then attempt to mount the drive with the followingcrw-r----- 1 root operator 0x60 Jul 14 21:34 /dev/cd0
so tried the following without much successThis disc contains a "UDF" file system and requires an operating system that supports the ISO-13346 "UDF" file system specification.
mount -t iso13446 /dev/cd0 /media/dvdrom
mount: /dev/cd0: Operation not supported by device
mount -t udf /dev/cd0 /media/dvdrom
mount_udf: /dev/cd0: Invalid argument
mount_udf /dev/cd0 /media/dvdrom
mount /dev/cd0 /media/dvdrom
mount: /dev/cd0: Invalid argument
