I'm trying to install the CrashPlan plugin (3.6.3_1) and I'm getting errors post-install. I'm on FreeNAS-9.10.2-U5 (561f0d7a1).
The main error is:
That occurs at the end of the install and also when I try to view the "Installed" plugins.
During the install, these errors come up:
I've checked the jail, it has an IP address on the same network and I can ping the GW. Initially it had issues with DHCP, so I manually set an IP.
Still getting this error:
Ideas?
The main error is:
Aug 11 11:02:44 redgiant manage.py: [plugins.utils:91] Couldn't retrieve http://10.8.12.9/plugins/crashplan/1/_s/status: HTTP Error 503: OK
Aug 11 11:00:45 redgiant manage.py: [freeadmin.tree.tree:98] Failed to get item order Traceback (most recent call last): File "/usr/local/www/freenasUI/../freenasUI/freeadmin/tree/tree.py", line 95, in __lt__ return self.gname.lower() < other.gname.lower() AttributeError: 'int' object has no attribute 'lower' Aug 11 11:00:45 redgiant manage.py: [freeadmin.tree.tree:98] Failed to get item order Traceback (most recent call last): File "/usr/local/www/freenasUI/../freenasUI/freeadmin/tree/tree.py", line 95, in __lt__ return self.gname.lower() < other.gname.lower() AttributeError: 'int' object has no attribute 'lower' Aug 11 11:00:45 redgiant manage.py: [freeadmin.tree.tree:98] Failed to get item order Traceback (most recent call last): File "/usr/local/www/freenasUI/../freenasUI/freeadmin/tree/tree.py", line 95, in __lt__ return self.gname.lower() < other.gname.lower() AttributeError: 'int' object has no attribute 'lower' Aug 11 11:00:45 redgiant manage.py: [freeadmin.tree.tree:98] Failed to get item order Traceback (most recent call last): File "/usr/local/www/freenasUI/../freenasUI/freeadmin/tree/tree.py", line 95, in __lt__ return self.gname.lower() < other.gname.lower() AttributeError: 'int' object has no attribute 'lower' Aug 11 11:00:51 redgiant manage.py: [freeadmin.navtree:577] Couldn't retrieve http://10.8.12.9/plugins/crashplan/1/_s/treemenu: timed out
Aug 11 11:39:18 redgiant manage.py: [plugins.utils:91] Couldn't retrieve http://10.8.12.9/plugins/crashplan/1/_s/status: HTTP Error 503: OK
Ideas?
