mattlach
- Oct 14, 2012
A few post indicated CP does not support backup to CIFS resource hosted by Freenas, can anyone expand on this issue ?
If this is TRUE I expect CP can't backup files to any SAMBA server, this sound very unlikely to be valid ? any comments ?
I can't speak to SAMBA as I have never tried it. I can see how the client might block samba mounts in Windows, but this becomes a little tricker if you use the linux version, especially if you have statically mounted network shares using /etc/fstab
This is how I do it, but I use NFS instead of SAMBA. The NFS shares are mounted on the Linux install in /etc/fstab
Then a userspace reverse filesystem encryption is done using encfs, which is where I have told Crashplan to look for things to back up.
This works fantastically, (apart from the fact that it is tough to see which file is which, if I don't want to restore everything, as the file and folder names are all encrypted too.
So, I'm going to say, it depends.
If they have blocked anything, SMB shares on a Windows client are probably blocked. SMB shares on a Mac client might be. Statically mounted SMB shares on a Linux box, probably not, and statically mounted NFS shares on a Linux box, definitely not.
If you are hellbent on using Windows as your client OS, try some things to see if they work. Enable NFS and use it instead of SMB. Check if Crashplan will back up now. If not, try placing a symbolic link from the shared network file system to somewhere else on your windows machine and see if you can "trick" it.
