CrashPlan Central - Waiting for connection
Andrew076
My CrashPlan will connect to CrashPlan Central and start syncing then will disconnect. I looked over the logs and saw that it transferred about 13 files before it attempts to connect again.
Does anyone have any idea what is going on? I have about 1,300+ files to backup still and at this rate it will never get done...
depasseg
FreeNAS Replicant
Have you looked at the crashplan logs?
Andrew076
Yes I did. About three hours ago I did an update to FreeNAS. After that update it seems to have held the connection. It is currently sync. the block info (89% complete) but it has been connected since then. So, either the reboot kicked it into gear, or something in the update fixed it.
