Could not determine size - now can't access drive
Stux
Don't type the %
depasseg
FreeNAS Replicant
So is the current problem that you can view the contents of church_videos_3? If so, it's because there isn't a zfs mount point identified. So you can manually add it (not a great idea), or you can export that pool and import using the GUI.
OmarOmar
Hello Depasseg,
I would love to be able to view the contents of "Church_Videos_3" but I can't???
depasseg
FreeNAS Replicant
did you have issues using the GUI and that's why you are using the CLI? If so, then the following should allow you to see the contents of that dataset:
zfs set mountpoint=/mnt/Church_Videos_3 Church_Videos_3
ls /mnt/Church_Videos_3
