Correct UPS Settings?
Arkhen
I'm trying to make sure my UPS (CPS CP900EPFCLCD) has the correct settings on my TrueNAS server. I want to UPS to shut down my server after 5 minutes of running on battery, and then shut itself off when done.
Do the below settings look correct to you? I'm a bit iffy on the driver, and the UPS is connected via USB, not serial.
Sep 12 15:33:06 freenas ugen0.2: <CPS CP900EPFCLCD> at usbus0
Sep 12 15:33:06 freenas interface uhid.1 already present in the KLD 'kernel'!
Sep 12 15:33:06 freenas linker_load_file: /boot/kernel/uhid.ko - unsupported file type
Sep 12 15:33:06 freenas interface wmt.1 already present in the KLD 'kernel'!
Sep 12 15:33:06 freenas linker_load_file: /boot/kernel/wmt.ko - unsupported file type
Sep 12 15:33:34 freenas 1 2021-09-12T15:33:34.179151+02:00 freenas.local collectd 7226 - - nut plugin: nut_connect: upscli_connect (localhost, 3493) failed: Connection failure: Connection refused
Sep 12 15:36:04 freenas 1 2021-09-12T15:36:04.905445+02:00 freenas.local upsmon 7389 - - upsmon parent: read
Sep 12 15:36:04 freenas 1 2021-09-12T15:36:04.924567+02:00 freenas.local upsd 7381 - - mainloop: Interrupted system call
(the rest is blank)
TrueNAS uses NUT. All CPS seem to use the same USBHID-UPS drivers.
You can check if TrueNAS is monitoring the UPS with the following.
upsc ups
You can set the time to 30 seconds and flip the breaker (or unplug) to confirm shutdown works.
Keep in mind that if you add or remove a USB device, the UPS USB device port enumeration may change.
Re: https://networkupstools.org/stable-hcl.html
Arkhen
upsc ups
Your command gave me the following output, so I guess we're good?
root@freenas:~ # upsc ups
battery.charge: 100
battery.charge.low: 10
battery.charge.warning: 20
battery.mfr.date: CPS
battery.runtime: 2130
battery.runtime.low: 300
battery.type: PbAcid
battery.voltage: 24.0
battery.voltage.nominal: 24
device.mfr: CPS
device.model: CP900EPFCLCD
device.serial: 000000000000
device.type: ups
driver.name: usbhid-ups
driver.parameter.pollfreq: 30
driver.parameter.pollinterval: 2
driver.parameter.port: /dev/ugen0.2
driver.parameter.synchronous: no
driver.version: 2.7.4
driver.version.data: CyberPower HID 0.4
driver.version.internal: 0.41
input.transfer.high: 260
input.transfer.low: 170
input.voltage: 228.0
input.voltage.nominal: 230
output.voltage: 260.0
ups.beeper.status: disabled
ups.delay.shutdown: 20
ups.delay.start: 30
ups.load: 14
ups.mfr: CPS
ups.model: CP900EPFCLCD
ups.productid: 0501
ups.realpower.nominal: 540
ups.serial: 000000000000
ups.status: OL
