Just completed migration from Core to SCALE. Seemed to go well, except for one error. Under Jobs there is an error relating to "smb.synchronize_group_mappings". It appear after a reboot. I am using Active Directory.
The AD domain group memberships are visible using wbinfo -u/-g as expected.
Following some other forum post, I noticed that the output from the following command might be useful (although I'm not 100% sure what it does):
The output is:
Can anyone point me in the right direction to fix this, please?
Richard
midclt call core.get_jobs '[["method", "=", "smb.synchronize_group_mappings"]]' | jq
The output is:
[ { "id": 34, "method": "smb.synchronize_group_mappings", "arguments": [], "description": null, "abortable": false, "logs_path": null, "logs_excerpt": null, "progress": { "percent": 0, "description": "", "extra": null }, "result": null, "error": "(6, 'WBC_ERR_WINBIND_NOT_AVAILABLE: wbcInterfaceDetails failed', '../../nsswitch/py_wbclient.c:1680')", "exception": "Traceback (most recent call last):\n File \"/usr/lib/python3/dist-packages/middlewared/job.py\", line 426, in run\n await self.future\n File \"/usr/lib/python3/dist-packages/middlewared/job.py\", line 461, in __run_body\n rv = await self.method(*([self] + args))\n File \"/usr/lib/python3/dist-packages/middlewared/plugins/smb_/groupmap.py\", line 492, in synchronize_group_mappings\n await self.sync_foreign_groups()\n File \"/usr/lib/python3/dist-packages/middlewared/plugins/smb_/groupmap.py\", line 133, in sync_foreign_groups\n domain_info = await self.middleware.call('idmap.domain_info',\n File \"/usr/lib/python3/dist-packages/middlewared/main.py\", line 1306, in call\n return await self._call(\n File \"/usr/lib/python3/dist-packages/middlewared/main.py\", line 1266, in _call\n return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args)\n File \"/usr/lib/python3/dist-packages/middlewared/main.py\", line 1169, in run_in_executor\n return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs))\n File \"/usr/lib/python3.9/concurrent/futures/thread.py\", line 52, in run\n result = self.fn(*self.args, **self.kwargs)\n File \"/usr/lib/python3/dist-packages/middlewared/plugins/idmap.py\", line 343, in domain_info\n return WBClient().domain_info()\n File \"/usr/lib/python3/dist-packages/middlewared/plugins/idmap_/utils.py\", line 53, in __init__\n self.ctx = wbclient.Ctx()\nwbclient.WBCError: (6, 'WBC_ERR_WINBIND_NOT_AVAILABLE: wbcInterfaceDetails failed', '../../nsswitch/py_wbclient.c:1680')\n", "exc_info": { "repr": "WBCError(6, 'WBC_ERR_WINBIND_NOT_AVAILABLE: wbcInterfaceDetails failed', '../../nsswitch/py_wbclient.c:1680')", "type": "WBCError", "extra": null }, "state": "FAILED", "time_started": { "$date": 1672700269702 }, "time_finished": { "$date": 1672700271152 } } ]
Richard
