Zaaphod
- Dec 15, 2015
I would like to know the best way of copying or moving either individual files or entire directories from one dataset to another directly on the FreeNAS system.
I don't care for the idea of mapping network drives to this for the following reasons:
1. desktop systems do not have ECC RAM and if I am copying data through the desktop system, all bytes of data must go through the desktop RAM to accomplish this
2. it's slower to send everything over the network and back again
3. it ties up the desktop system until it's done
I realize I can do this via the command line by using SSH and use CP or MV commands, but this is very tedious especially if you are trying to re-organize an entire directory structure or if you are dealing with a lot of long file names. So I'm wondering if there is some easy GUI way to manipulate files directly on the server without them going through the desktop system? I'm basically wanting to do something like "browse datastore" on an ESXi server, where I can open two browsers and copy or move files from one to the other using a GUI interface and not need to type all the long paths and file names.
Any ideas?
Any ideas?
