zaidpirwani
- Mar 14, 2022
I am a new user and tried to search for a similar problem but couldnt find much, except for one post which mentioned rsync but the data they need to copy is quite less.
I have recently installed TRUENAS CORE on an HP Z800 system, 12GB RAM, created 1 pool with 3 WD Red HDDs of 10TB and have created a Windows Share.
Now I want to copy data from WD MyCloud Home which has 8TB HDD and almost 7TB is full to my new NAS.
I thought this would be simple, remove HDD from MyCloud, put in the same machine and import disk, but apparently WD has some sort of non-simple file system and it does not show data on Windows/Linux machines.
Still tried to use IMPORT DISK, I dont think it will work, showing 24 partitions and I dont think the available file system options are correct.
So, what would be the BEST way to do this copy operation while the HDD is in the MyCloud and accessible locally via Windows Share?
I would ideally NOT want another laptop in between.
I have a switch (currently a 10/100) trying to get a better Lan Switch, both WD Cloud and TrueNAS Machine will be connected to the same switch.
NO LAPTOP METHOD: where I access the WD MyCloud Windows Share through the web interface, start the copy operation and then close it and it continues to copy
LAPTOP METHOD: I open both windows shares in one laptop and start COPY operation via TeraCopy or some other alternate ?
