PsychoAlex
- Mar 5, 2023
Hi All,
Looking for some general advice on a HP ProLiant DL380p Gen8 from Bargain Hardware. I am currently using a rather old i5 mini-atx system with 8gb of ram and a random collection of old 1TB HDDs connected to a LSI MegaRAID 9240-8i that I have flashed to IT mode.
I am running currently using it to run a Jellyfin container, which is working fantastically. However, as I was limited in resources and mostly wanting to give Scale a good try, my drives are setup as a Stripe with no redundancy and I have very limited RAM. So I am looking to drop some cash on an older server platform and build a proper homelab out of it, been on my wish list for years.
What I would like some advice on specifically:
Is the p420i compatible with Scale out of the box? All of the information I have found on it on the forums are either for older versions of Core or from pre-2018
Is the P420i 2GB FBWC (SAS/SATA) RAID Kit as an option the best route to go, or should I grab another LSI MegaRAID 9240-8i, flash it as well, then use the two of them instead?
I have already done some searching, and it appears the P420i does support some form of HBA passthrough however I cannot find anything concrete. Dropping this amount of cash is obviously a somewhat significant investment for a homelab and I want to make sure it's possible before I pull the trigger.
Any other suggestions and advice welcome.
