Chris Shores
 - Mar 18, 2015
When trying to apply updates the download runs for a while and then continually stops with the error 'Connection Reset By Peer'
Is this a know issue? The computer I am using has an extremely stable connection so I don't this that is the problem.
FYI - It always seems to stop at 11%/22% on the top/bottom gauges respectively.
Thanks!
Thanks!
