Device: /dev/ada4, 2 Currently unreadable (pending) sectors
antsrealm
I have received this email message today.
his message was generated by the smartd daemon running on:
  host name:  freenas
  DNS domain: local
The following warning/error was logged by the smartd daemon:
Device info:
WDC WD30EZRX-00MMMB0, S/N:WD-WMAWZ0418179, WWN:5-0014ee-206f8271f, FW:80.00A80, 3.00 TB
For details see host's SYSLOG.
You can also use the smartctl utility for further investigation.
No additional messages about this problem will be sent.
What should I do from here ?
Also here is a copy and paste from the shell that is in the web interface:-
May  9 10:06:11 freenas smbd[25888]: [2014/05/09 10:06:11.807370,  0] ../libcli/auth/ntlm_check.c:54(smb_pwd_check_ntlmv1)
May  9 10:06:11 freenas smbd[25888]:  smb_pwd_check_ntlmv1: incorrect password length (74)
May  9 10:06:32 freenas smbd[25888]: [2014/05/09 10:06:32.328524,  0] ../libcli/auth/ntlm_check.c:54(smb_pwd_check_ntlmv1)
May  9 10:06:32 freenas smbd[25888]:  smb_pwd_check_ntlmv1: incorrect password length (74)
May  9 10:06:32 freenas smbd[25888]: [2014/05/09 10:06:32.329144,  0] ../libcli/auth/ntlm_check.c:54(smb_pwd_check_ntlmv1)
May  9 10:37:46 freenas smartd[2981]: Device: /dev/ada4, 2 Currently unreadable (pending) sectors
May  9 10:37:51 freenas smartd[2981]: Device: /dev/ada4, 2 Currently unreadable (pending) sectors
May  9 11:37:46 freenas smartd[2981]: Device: /dev/ada4, 2 Currently unreadable (pending) sectors
May  9 11:39:32 freenas sshd[27762]: fatal: Read from socket failed: Connection reset by peer [preauth]
May  9 11:39:32 freenas sshd[27764]: fatal: Read from socket failed: Connection reset by peer [preauth]
May  9 11:39:32 freenas sshd[27760]: fatal: Read from socket failed: Connection reset by peer [preauth]
May  9 11:39:32 freenas sshd[27766]: fatal: Read from socket failed: Connection reset by peer [preauth]
May  9 11:46:47 freenas sshd[28273]: fatal: Read from socket failed: Connection reset by peer [preauth]
May  9 11:46:47 freenas sshd[28275]: fatal: Read from socket failed: Connection reset by peer [preauth]
May  9 11:46:47 freenas sshd[28277]: fatal: Read from socket failed: Connection reset by peer [preauth]
May  9 12:37:46 freenas smartd[2981]: Device: /dev/ada4, 2 Currently unreadable (pending) sectors
May  9 13:34:00 freenas sshd[29885]: fatal: Read from socket failed: Connection reset by peer [preauth]
May  9 13:34:00 freenas sshd[29883]: fatal: Read from socket failed: Connection reset by peer [preauth]
May  9 13:34:01 freenas sshd[29887]: fatal: Read from socket failed: Connection reset by peer [preauth]
May  9 13:37:46 freenas smartd[2981]: Device: /dev/ada4, 2 Currently unreadable (pending) sectors
May  9 13:53:08 freenas sshd[30445]: fatal: Read from socket failed: Connection reset by peer [preauth]
May  9 13:53:09 freenas sshd[30449]: fatal: Read from socket failed: Connection reset by peer [preauth]
May  9 13:53:10 freenas sshd[30446]: fatal: Read from socket failed: Connection reset by peer [preauth]
May  9 14:07:38 freenas manage.py: [common.pipesubr:57] Popen()ing: /usr/local/bin/warden list  -v
May  9 14:07:38 freenas last message repeated 2 times
Stop refresh
What should I do from here. This server host stuff for my small business so it's important I get this back to 100%
Thanks,
Tony.
antsrealm
Also here is the zpool status result:-
[root@freenas ~]# zpool status
  pool: NAS
state: ONLINE
  scan: scrub repaired 0 in 10h11m with 0 errors on Tue Apr  1 10:11:42 2014
        NAME                                            STATE    READ WRITE CKS
UM
        NAS                                            ONLINE      0    0
0
          raidz1-0                                      ONLINE      0    0
0
            gptid/71cbb176-bcb1-11e1-aa48-c8600014c8a1  ONLINE      0    0
0
            gptid/7266b6e7-bcb1-11e1-aa48-c8600014c8a1  ONLINE      0    0
0
            gptid/72f9c4f5-bcb1-11e1-aa48-c8600014c8a1  ONLINE      0    0
0
            gptid/738c5264-bcb1-11e1-aa48-c8600014c8a1  ONLINE      0    0
0
            gptid/74228c86-bcb1-11e1-aa48-c8600014c8a1  ONLINE      0    0
0
errors: No known data errors
[root@freenas ~]#
antsrealm
Here is the smartctl result for ada4
[root@freenas] ~# smartctl -a /dev/ada4
smartctl 6.1 2013-03-16 r3800 [FreeBSD 9.1-STABLE amd64] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:    Western Digital Caviar Green (AF, SATA 6Gb/s)
Device Model:    WDC WD30EZRX-00MMMB0
Serial Number:    WD-WMAWZ0418179
LU WWN Device Id: 5 0014ee 206f8271f
Firmware Version: 80.00A80
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:    512 bytes logical, 4096 bytes physical
ATA Version is:  ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri May  9 14:43:36 2014 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x84) Offline data collection activity
                                        was suspended by an interrupting command from host.
Self-test execution status:      ( 117) The previous self-test completed having
                                        the read element of the test failed.
data collection:                (51660) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (  2) minutes.
Extended self-test routine
recommended polling time:        ( 496) minutes.
Conveyance self-test routine
recommended polling time:        (  5) minutes.
SCT capabilities:              (0x3035) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAG    VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate    0x002f  200  200  051    Pre-fail  Always      -      0
  3 Spin_Up_Time            0x0027  177  152  021    Pre-fail  Always      -      8150
  4 Start_Stop_Count        0x0032  100  100  000    Old_age  Always      -      56
  5 Reallocated_Sector_Ct  0x0033  200  200  140    Pre-fail  Always      -      0
  7 Seek_Error_Rate        0x002e  200  200  000    Old_age  Always      -      0
  9 Power_On_Hours          0x0032  078  078  000    Old_age  Always      -      16162
10 Spin_Retry_Count        0x0032  100  253  000    Old_age  Always      -      0
11 Calibration_Retry_Count 0x0032  100  253  000    Old_age  Always      -      0
12 Power_Cycle_Count      0x0032  100  100  000    Old_age  Always      -      54
192 Power-Off_Retract_Count 0x0032  200  200  000    Old_age  Always      -      25
193 Load_Cycle_Count        0x0032  155  155  000    Old_age  Always      -      136290
194 Temperature_Celsius    0x0022  120  106  000    Old_age  Always      -      32
196 Reallocated_Event_Count 0x0032  200  200  000    Old_age  Always      -      0
197 Current_Pending_Sector  0x0032  200  200  000    Old_age  Always      -      2
198 Offline_Uncorrectable  0x0030  200  200  000    Old_age  Offline      -      0
199 UDMA_CRC_Error_Count    0x0032  200  200  000    Old_age  Always      -      0
200 Multi_Zone_Error_Rate  0x0008  200  200  000    Old_age  Offline      -      1
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline      Completed: read failure      50%    16148        4256912
# 2  Extended offline    Completed: read failure      90%    15980        4256912
# 3  Short offline      Completed: read failure      50%    15908        4256912
# 4  Short offline      Completed without error      00%    15668        -
# 5  Short offline      Completed without error      00%    15429        -
# 6  Extended offline    Completed without error      00%    15269        -
# 7  Short offline      Completed without error      00%    15165        -
# 8  Short offline      Completed without error      00%    14925        -
# 9  Short offline      Completed without error      00%    14685        -
#10  Extended offline    Completed without error      00%    14526        -
#11  Short offline      Completed without error      00%    14254        -
#12  Short offline      Completed without error      00%    14015        -
#13  Extended offline    Completed without error      00%    13855        -
#14  Short offline      Completed without error      00%    13750        -
#15  Short offline      Completed without error      00%    13511        -
#16  Short offline      Completed without error      00%    13271        -
#17  Extended offline    Completed without error      00%    13112        -
#18  Short offline      Completed without error      00%    13007        -
#19  Short offline      Completed without error      00%    12767        -
#20  Short offline      Completed without error      00%    12528        -
#21  Extended offline    Completed without error      00%    12368        -
[root@freenas] ~#
antsrealm
Looks like this is the problem area :--
antsrealm
After doing a read around the forum it looks like this is grounds to replace the disk and I should do so Immediately. At the moment I have all WD green disks, is there any problem with replacing the failed green disk with a WD red as that is the path I would like to take (I think :p)
Scareh
you can swap green and reds all around, don't worry about that.
You should read cyberjock's signature on why Raidz1 is dead and use Raidz2, especially if its bussiness data, which seem to be important
antsrealm
Yeah I want to change to Z2 I'm aware of the need but it's not possible to add an extra HDD to the current pool is it ? Also I have a pending upgrade where I will replace everything to the preferred hardware (ECC Ram etc.) just not quite there yet.
