I have the FreeNAS up and working.
I would like to reset the network interface (re0) from DHCP to Fixed IP. Can I use the FreeNAS GUI to do that or do I have to use the FreeBSD console setup option #1 (Configure Network Interfaces)? If it can be done through the GUI, are there instructions? If not, where could I find instruction for FreeBSD network interfaces configuration?
Thanks,
AG
Thanks,
AG
