Config lost after reboot
TeChn4K
Hi all,
Yesterday I launch the last FreeNAS upgrade, without reboot immediately. Today, I continued to tweek my FreeNAS instance : enable new plugin, create new dataset, add CA and Certs, create user group to manage files permissions, etc.
Then tonight I saw the yellow dot flash : all running great, perfect configuration, time to restart (softly with the restart GUI button !)
And once started, I had lost a significant number of things ... :
- No more NIC configuration
- last user group created disappears
- Syncthing jail ok (running great) but his plugin not seems to be installed in the GUI
- Last jails storages configured gone
- CA and certs not displayed anymore, https checkbox unticked
My config is back in a before upgrade state.
I think the upgrade process did not consider my config changes after that. Hard !
So, I will backup my config twice before to do anything !
Is there a way to get back the Syncthing plugin enabled without create a new jail instance ? Syncthing jail is there and works perfectly.
That's the second thread today with such a weird situation.
What hardware are you using and what version did you update from.
TeChn4K
Hardware list :
Supermicro A1SAI-2550F
2x 8GB Kingston DDR3L PC12800 ECC
4x WD RED 3TB - RAID10
SanDisk Extreme 32GB
BeQuiet! Pure Power 9 400W CM
Updated from 9.10-STABLE to 9.10.1-U2
m0nkey_
Hmm, this does not bode well if we're still seeing bugs after the U2 update. This makes me slightly nervous to update (again).
I'd say a bug ticket is warranted, with two very similar cases...
TeChn4K
