Hey all, new here. Finally getting around to putting together a NAS build that I've been putting off for the last few years.
The build is primarily meant to function as a Plex/Media server to accommodate up to ~4 simultaneous 1080p transcodes with headroom to consider higher resolutions in the future. It will also serve as general home storage, a Teamspeak server, ownCloud.. and I have some other ideas I've not yet committed to.
I plan to start with 4x 4TB drives, and add more in a few months. Thinking about doing RAID6, but open to discussion.
Here's the build on pcpartpicker: http://pcpartpicker.com/p/Bq3fMp (ignore the ram, couldn't add the stuff I wanted)
Mobo: ASRock C236 WSI Mini-ITX server board (dual gigabit ethernet, 8x SATA3)
CPU: Xeon E3-1240 v5 Skylake
RAM: 32GB (2x 16GB) Crucial DDR4 2133 ECC UDIMM (Model: CT2K16G4WFD8213)
Case: Fractal Design Node 304 (6x bays)... possibly U-NAS NSC-800 (8x bays)
Drives: 4x 4TB HGST 0S03664 NAS drives (adding two more later)
PSU: Antec EarthWatts Green 380W (wattage is overkill, I know.. open to suggestions)
UNDECIDED:
A couple more things....
I mainly want a compatibility/part check.. but I am open to ANY suggestions offered, as this is my first build and I want to get everything right.
Thanks in advance!
UNDECIDED:
- Boot drive... SSD or USB stick? I'm OK with spending another $50 on a small SSD if it benefits the system.
- Heatsink/fan... need to research size requirements more, considering the Mini-ITX case. Noise, however, is another major consideration.
- I'm not dead set on a RAID configuration yet.. it's a toss up between RAID6 and RAID10 (EDIT: Correction... manual states only RAID 0,1,5,10 are supported..)
- Registered/Unbuffered/Buffered ECC RAM confuses the heck out of me. I think I chose compatible RAM, but I need some extra eyes to double check that. ASRock makes no distinction whatsoever, not on their website, not even in the motherboard manual. It just says "ECC/non-ECC".
- Regardless of the RAID mode I decide on.. is it easy to add 2 more drives later on?
- How well supported is Skylake in FreeNAS these days? I read about some issues.. but the threads I found were mostly from Nov/Dec 2015.
Thanks in advance!
