Monty Carlo
- Dec 29, 2013
I'm planning to build a FreeNAS home server and my budget is on the tight side. Can anyone comment on these components especially in regard to the motherboard/processor choice:
Motherboard: ASRock E3C2262I
Case: Lian Li PC-Q25B
CPU: Intel Pentium G3220 (may consider upgrading to Xeon e3 1200 down the line)
RAM: Crucial 8GB DDR3 Unbuffered ECC
Power Supply: Seasonic SSR-360GP 360 watt, Gold Cert
Hard Drive: WD Red 2 TB (unsure on the number of drives, but no more than 3)
Also, will this setup support a ZFS file system?
EDIT: Those were supposed to be 2 TB
