Hello, I am after some advice,
I have a volume on a single hard disk (bad practice I know!) that I wish to remove as i think it will fail in the near future (unreadable sectors) . I wish to clone this drive to another disk, what is the best way to go about this? I tried using Rsync, however when copying the folder that contains my jail it appears to also try and copy the mounts that are within the jail as well (which is from a separate volume). ie it copies /mnt/downloads/mnt/Media. With downloads being my jail and the media folder being on another volume.
If i let that happen i will run out of space very quickly!
Is there another way to go about this or do i have to reconfigure my jail?
Thanks in advance
Thanks in advance
