FreeBSD 9.2-RELEASE-p3 #0 r262572+825d682: Sat Mar 1 10:02:19 PST 2014
root@build.ixsystems.com:/home/jkh/checkout/freenas/os-base/amd64/tank/home/jkh/checkout/freenas/FreeBSD/src/sys/FREENAS.amd64 amd64
gcc version 4.2.1 20070831 patched [FreeBSD]
CPU: AMD Athlon(tm) II X2 250 Processor (3000.07-MHz K8-class CPU)
Origin = "AuthenticAMD" Id = 0x100f62 Family = 0x10 Model = 0x6 Stepping = 2
Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
Features2=0x802009<SSE3,MON,CX16,POPCNT>
AMD Features=0xee500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM,3DNow!+,3DNow!>
AMD Features2=0x37ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT>
TSC: P-state invariant
real memory = 4831838208 (4608 MB)
avail memory = 3966414848 (3782 MB)
Event timer "LAPIC" quality 400
ACPI APIC Table: <7612MS A7612200>
FreeBSD/SMP: Multiprocessor System Detected: 2 CPUs
FreeBSD/SMP: 1 package(s) x 2 core(s)
cpu0 (BSP): APIC ID: 0
cpu1 (AP): APIC ID: 1
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 1.1> irqs 0-23 on motherboard
kbd1 at kbdmux0
cryptosoft0: <software crypto> on motherboard
aesni0: No AESNI support.
padlock0: No ACE support.
acpi0: <7612MS A7612200> on motherboard
acpi0: Power Button (fixed)
acpi0: reservation of fee00000, 1000 (3) failed
acpi0: reservation of 0, a0000 (3) failed
acpi0: reservation of 100000, dff00000 (3) failed
cpu0: <ACPI CPU> on acpi0
cpu1: <ACPI CPU> on acpi0
attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
Timecounter "i8254" frequency 1193182 Hz quality 0
Event timer "i8254" frequency 1193182 Hz quality 100
atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
Event timer "RTC" frequency 32768 Hz quality 0
Timecounter "ACPI-fast" frequency 3579545 Hz quality 900
acpi_timer0: <24-bit timer at 3.579545MHz> port 0x2008-0x200b on acpi0
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pci0: <ACPI PCI bus> on pcib0
pci0: <memory, RAM> at device 0.0 (no driver attached)
isab0: <PCI-ISA bridge> port 0x2f00-0x2fff at device 1.0 on pci0
isa0: <ISA bus> on isab0
pci0: <serial bus, SMBus> at device 1.1 (no driver attached)
pci0: <memory, RAM> at device 1.2 (no driver attached)
pci0: <processor> at device 1.3 (no driver attached)
pci0: <memory, RAM> at device 1.4 (no driver attached)
ohci0: <OHCI (generic) USB controller> mem 0xfbf7f000-0xfbf7ffff irq 22 at device 2.0 on pci0
usbus0 on ohci0
ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfbf7ec00-0xfbf7ecff irq 23 at device 2.1 on pci0
usbus1: EHCI version 1.0
usbus1 on ehci0
ohci1: <OHCI (generic) USB controller> mem 0xfbf7d000-0xfbf7dfff irq 20 at device 4.0 on pci0
usbus2 on ohci1
ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfbf7e800-0xfbf7e8ff irq 21 at device 4.1 on pci0
usbus3: EHCI version 1.0
usbus3 on ehci1
pcib1: <ACPI PCI-PCI bridge> at device 8.0 on pci0
pci1: <ACPI PCI bus> on pcib1
nfe0: <NVIDIA nForce MCP77 Networking Adapter> port 0xc080-0xc087 mem 0xfbf7c000-0xfbf7cfff,0xfbf7e400-0xfbf7e4ff,0xfbf7e000-0xfbf7e00f irq 22 at device 10.0 on pci0
miibus0: <MII bus> on nfe0
rgephy0: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 1 on miibus0
rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow
nfe0: Ethernet address: 40:61:86:64:30:bd
pcib2: <ACPI PCI-PCI bridge> at device 11.0 on pci0
pci2: <ACPI PCI bus> on pcib2
vgapci0: <VGA-compatible display> port 0xdc00-0xdc7f mem 0xfc000000-0xfcffffff,0xf0000000-0xf7ffffff,0xf8000000-0xf9ffffff irq 23 at device 0.0 on pci2
pcib3: <ACPI PCI-PCI bridge> irq 16 at device 16.0 on pci0
pci3: <ACPI PCI bus> on pcib3
pcib4: <PCI-PCI bridge> at device 0.0 on pci3
pci4: <PCI bus> on pcib4
pcib5: <PCI-PCI bridge> at device 0.0 on pci4
pci5: <PCI bus> on pcib5
pcib6: <PCI-PCI bridge> at device 2.0 on pci4
pci6: <PCI bus> on pcib6
pcib7: <PCI-PCI bridge> at device 3.0 on pci4
pci7: <PCI bus> on pcib7
arcmsr0: <Areca SAS 6G Host Adapter RAID Controller (RAID6 capable)
arcmsr version 1.20.00.28 2013-09-13
> port 0xe800-0xe8ff mem 0xfdff0000-0xfdffffff,0xfdf80000-0xfdfbffff irq 19 at device 0.0 on pci7
Areca RAID adapter0: ARC-1882 F/W version V1.52 2013-08-29
pcib8: <ACPI PCI-PCI bridge> irq 17 at device 19.0 on pci0
pci8: <ACPI PCI bus> on pcib8
pcib9: <ACPI PCI-PCI bridge> irq 18 at device 20.0 on pci0
pci9: <ACPI PCI bus> on pcib9
amdtemp0: <AMD CPU On-Die Thermal Sensors> on hostb3
acpi_button0: <Power Button> on acpi0
sc0: <System console> at flags 0x100 on isa0
sc0: VGA <16 virtual consoles, flags=0x300>
vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0
atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0
atkbd0: <AT Keyboard> irq 1 on atkbdc0
kbd0 at atkbd0
atkbd0: [GIANT-LOCKED]
wbwd0: HEFRAS and EFER do not align: EFER 0x2e DevID 0xff DevRev 0xff CR26 0xff
wbwd0: HEFRAS and EFER do not align: EFER 0x4e DevID 0x07 DevRev 0x23 CR26 0x80
hwpstate0: <Cool`n'Quiet 2.0> on cpu0
Timecounters tick every 1.000 msec
ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled
DUMMYNET 0xfffffe000278a000 with IPv6 initialized (100409)
load_dn_sched dn_sched RR loaded
load_dn_sched dn_sched WF2Q+ loaded
load_dn_sched dn_sched FIFO loaded
load_dn_sched dn_sched PRIO loaded
load_dn_sched dn_sched QFQ loaded
usbus0: 12Mbps Full Speed USB v1.0
usbus1: 480Mbps High Speed USB v2.0
usbus2: 12Mbps Full Speed USB v1.0
usbus3: 480Mbps High Speed USB v2.0
ugen0.1: <nVidia> at usbus0
uhub0: <nVidia OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus0
ugen1.1: <nVidia> at usbus1
uhub1: <nVidia EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
ugen2.1: <nVidia> at usbus2
uhub2: <nVidia OHCI root HUB, class 9/0, rev 1.00/1.00, addr 1> on usbus2
ugen3.1: <nVidia> at usbus3
uhub3: <nVidia EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus3
uhub0: 6 ports with 6 removable, self powered
uhub2: 6 ports with 6 removable, self powered
da0 at arcmsr0 bus 0 scbus0 target 2 lun 0
da0: <WDC WD30EFRX-68AX9N0 R001> Fixed Direct Access SCSI-5 device
da0: Serial Number WD-WMC1T3166645
da0: 600.000MB/s transfers
da0: Command Queueing enabled
da0: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
da1 at arcmsr0 bus 0 scbus0 target 2 lun 1
da1: <WDC WD30EFRX-68AX9N0 R001> Fixed Direct Access SCSI-5 device
da1: Serial Number WD-WMC1T3155210
da1: 600.000MB/s transfers
da1: Command Queueing enabled
da1: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
pass3 at arcmsr0 bus 0 scbus0 target 16 lun 0
pass3: <Areca RAID controller R001> Fixed Processor SCSI-0 device
da2 at arcmsr0 bus 0 scbus0 target 2 lun 2
da2: <WDC WD30EFRX-68AX9N0 R001> Fixed Direct Access SCSI-5 device
da2: Serial Number WD-WMC1T3958920
da2: 600.000MB/s transfers
da2: Command Queueing enabled
da2: 2861588MB (5860533168 512 byte sectors: 255H 63S/T 364801C)
SMP: AP CPU #1 Launched!
Timecounter "TSC-low" frequency 1500033739 Hz quality 800
GEOM: da0: the secondary GPT table is corrupt or invalid.
GEOM: da0: using the primary only -- recovery suggested.
GEOM: da1: the secondary GPT table is corrupt or invalid.
GEOM: da1: using the primary only -- recovery suggested.
Root mount waiting for: usbus3 usbus1
uhub1: 6 ports with 6 removable, self powered
uhub3: 6 ports with 6 removable, self powered
Root mount waiting for: usbus1
ugen1.2: <OCZ Technology> at usbus1
umass0: <OCZ Technology RALLY2, class 0/0, rev 2.00/11.00, addr 2> on usbus1
umass0: SCSI over Bulk-Only; quirks = 0x0100
umass0:2:0:-1: Attached to scbus2
Trying to mount root from ufs:/dev/ufs/FreeNASs1a [ro]...
mountroot: waiting for device /dev/ufs/FreeNASs1a ...
da3 at umass-sim0 bus 0 scbus2 target 0 lun 0
da3: <OCZ RALLY2 1100> Removable Direct Access SCSI-0 device
da3: Serial Number AA04012700336500
da3: 40.000MB/s transfers
da3: 3824MB (7831552 512 byte sectors: 255H 63S/T 487C)
da3: quirks=0x2<NO_6_BYTE>
GEOM_RAID5: Module loaded, version 1.1.20130907.44 (rev 5c6d2a159411)
GEOM_RAID5: RAID5: device created (stripesize=131072).
GEOM_RAID5: RAID5: da1(1): disk attached.
GEOM_RAID5: RAID5: da0(3): disk attached.
GEOM_RAID5: RAID5: activated (forced) (need about 76MiB kmem (max)).
GEOM: raid5/RAID5: the secondary GPT table is corrupt or invalid.
GEOM: raid5/RAID5: using the primary only -- recovery suggested.
GEOM_RAID5: RAID5: request failed: R 5.
