Volume storage (ZFS) status is UNKNOWN - zpool import fails
TheWizzard
Ericloewe, I understand and accept this, but it doesn't help me much at this moment...
Besides, then I wonder why FreeNAS is still carrying the 2GB as Minimum on their website...
Anyways: any suggestions, how I can solve this problem? It is weird, that in 8.3 three disks show up and in 9.2.1.8 only two... Any idea what the cause could be?
Anodos: Thanks for your help so far. I tried hooking the drives to another machine and the same problem occurs...
anodos
Sambassador
The 2GB refers to UFS. 8GB is the minimum for ZFS. In 8.3 are you able to import the pool from the console? Boot 8.3 and post "zpool status [pool]"
gpsguy
Active Member
Do what?
how do i do that?
You've already said that you were able to boot 8.3 and it found 3 of the 4 disks. Do that again.
And, try zpool import storage like you said you did in message #3. Also run zpool status storage and post your results in code tags. It will preserve the formatting.
anodos
Sambassador
Do what?
To explain a bit further. 8.3 gives you the best chance of recovery.
3/4 disks *may* be doable, but 2/4 disks for raidz1 is not possible..
TheWizzard
Sorry for my absence (was on a business trip) and thanks for all your help!
I booted 8.3 again..
Here is the output of zpool import storage:
cannot import 'storage': no such pool or dataset
        Destroy and re-create the pool from
        a backup source.
here the output for zpool import
 pool: storage
  state: UNAVAIL
status: One or more devices are missing from the system.
action: The pool cannot be imported. Attach the missing
        devices and try again.
   see: http://www.sun.com/msg/ZFS-8000-3C
        storage                                         UNAVAIL  insufficient re
plicas
          raidz1-0                                      UNAVAIL  insufficient re
plicas
            gptid/e30eebe4-42e1-11e2-911d-00151731a67f  ONLINE
            4694448216509377380                         UNAVAIL  cannot open
            16020346307811284986                        UNAVAIL  cannot open
            gptid/e4d80488-42e1-11e2-911d-00151731a67f  ONLINE
here the output for status zpool storage:+
cannot open 'storage': no such pool
Odd fact: the disk manager shows me still three of the four drives and shows them with Serial, Status and no S.M.A.R.T errors... But in the shell there are only two...
Besides: zdb -eh gives me the following:
zdb -eh storage
zdb: can't open 'storage': File exists
Hope that helps. Again: thank you so much for your support! :)
SweetAndLow
Sweet'NASty
I was wondering where are you seeing this 2Gig memory requirement? I specifically see them call out 8Gig on their website.
http://www.freenas.org/faq/
Yeah, some website listed 2GB (which was the old minimum) and for some reason wasn't updated.
To be 100% accurate, 2GB is still the minimum if you are using UFS. But as the 9.3-BETA is literally days away from being released you'd be silly to use UFS. Its dead from FreeNAS and if your hardware can't handle ZFS you probably should find another OS to use (like NAS4Free).
TheWizzard
anodos: hm, not good... well, i assume there is a chance to get it back but it will be a matter of resources (money) --> i just would love to get around professional data recovery... still, i wonder why it seems to find the storage in with some commands and in some menus, but not in all... Again: the disk manager finds three of four disks intact...
SweetAndLow, Ericloewe, cyberjock: yes, when I posted it, it was still online - unfortunately, for noobs like me, the information that the 2GB applied to UFS was given nowhere... anyways: can't change that one anymore - but still would love to recover my data :P
