As noted in an earlier post I have been using the FreeNAS B2 sync system and it has ended up logging a massive amount of Class C transactions (hundreds of dollars worth a month till I set the cap). Now I have capped it the sync shuts down after 30 minutes due to running out of Class C transactions.
I want to establish if this is a bug or if it's meant to do that! So I have a question for anyone kind enough to respond
1) How much data do you have stored in a B2 bucket GB/TB?
2) How many files do you have in your bucket?
3) Assuming daily backup/sync, how many Class C transactions do you log?
Thanks for any response - rough numbers will do, just trying to find out if this is what I should expect. And if it is, I'll be buying my own server to put remotely somewhere!
