highlow
- Mar 14, 2022
Hello Community,
I was trying to install ClamAV and it won't install properly. I don't know what I'm doing incorrectly. I was using a private static IP for the ClamAV installation.
Could you please help? What does that VNET failure mean?
[2022/03/14 17:19:56] (INFO) iocage.callback():71 - Installing updates...Scanning /mnt/Storage_Pool/iocage/releases/12.2-RELEASE/root/usr/share/certs/blacklisted for certificates... [2022/03/14 17:19:56] (INFO) iocage.callback():71 - Scanning /mnt/Storage_Pool/iocage/releases/12.2-RELEASE/root/usr/share/certs/trusted for certificates... [2022/03/14 17:20:03] (INFO) iocage.callback():71 - done. [2022/03/14 17:20:16] (DEBUG) iocage.__start_jail__():248 - Grabbing IPv4 default route [2022/03/14 17:20:16] (DEBUG) iocage.__start_jail__():250 - Default IPv4 Gateway: 10.50.1.1 [2022/03/14 17:20:16] (DEBUG) iocage.__start_jail__():253 - Grabbing IPv6 default route [2022/03/14 17:20:16] (DEBUG) iocage.__start_jail__():255 - Default IPv6 Gateway: none [2022/03/14 17:20:18] (DEBUG) iocage.start_network():1129 - Setting default route 10.50.1.1 [2022/03/14 17:20:23] (ERROR) middlewared.job.run():379 - Job <bound method accepts.<locals>.wrap.<locals>.nf of <middlewared.plugins.jail_freebsd.PluginService object at 0x819e3cc40>> failed Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_plugin.py", line 319, in fetch_plugin jaildir, _conf, repo_dir = self.__fetch_plugin_create__(props) File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_plugin.py", line 565, in __fetch_plugin_create__ iocage_lib.ioc_create.IOCCreate( File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_create.py", line 101, in create_jail return self._create_jail(jail_uuid, location) File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_create.py", line 660, in _create_jail iocage_lib.ioc_start.IOCStart(jail_uuid, location, File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_start.py", line 87, in __init__ raise e File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_start.py", line 84, in __init__ self.__start_jail__() File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_start.py", line 755, in __start_jail__ iocage_lib.ioc_common.logit({ File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_common.py", line 107, in logit callback(content, exception) File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_common.py", line 80, in callback raise callback_exception(message) RuntimeError: Stopped clamav1 due to VNET failure During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run await self.future File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 405, in __run_body rv = await self.middleware.run_in_thread(self.method, *([self] + args)) File "/usr/local/lib/python3.9/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 979, in nf return f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/jail_freebsd.py", line 296, in do_create ioc.IOCage(callback=progress_callback, silent=False).fetch(**{ File "/usr/local/lib/python3.9/site-packages/iocage_lib/iocage.py", line 1072, in fetch plugin_obj.fetch_plugin(props, 0, accept) File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_plugin.py", line 342, in fetch_plugin iocage_lib.ioc_common.logit({ File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_common.py", line 107, in logit callback(content, exception) File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_common.py", line 80, in callback raise callback_exception(message) RuntimeError: clamav1 had a failure Exception: RuntimeError Message: Stopped clamav1 due to VNET failure Partial plugin destroyed#
