heisenberg1977
- Nov 25, 2012
Attempting setting up a TrueNAS on my old tower. MBoard is an Asus Maximus V Gene
I had 2 x 3TB WD Red's and I received an error adding ada1 to the pool. I ran a SMART check on the disk and received an error. I ended up purchasing 2 new 6TB WD Red's and receive the following error. A manual SMART check on each new disk is successful but still encountering errors creating the pool.
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 355, in run
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 391, in __run_body
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 677, in do_create
await self.middleware.call('pool.format_disks', job, disks)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1305, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1262, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/format_disks.py", line 28, in format_disks
await asyncio_map(format_disk, disks.items(), limit=16)
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/asyncio_.py", line 16, in asyncio_map
return await asyncio.gather(*futures)
File "/usr/local/lib/python3.9/site-packages/middlewared/utils/asyncio_.py", line 13, in func
return await real_func(arg)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/format_disks.py", line 24, in format_disk
await self.middleware.call('disk.format', disk, swapgb if config['create_swap'] else 0, False)
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1273, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1166, in run_in_executor
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/disk_/format.py", line 11, in format
size = get_size_with_name(disk)
File "bsd/disk.pyx", line 37, in bsd.disk.get_size_with_name
FileNotFoundError: [Errno 2] No such file or directory: '/dev/ada1'
await self.future
