ClamAV installation failed.
highlow
Hello Community,
I was trying to install ClamAV and it won't install properly. I don't know what I'm doing incorrectly. I was using a private static IP for the ClamAV installation.
Could you please help? What does that VNET failure mean?
[2022/03/14 17:19:56] (INFO) iocage.callback():71 - Installing updates...Scanning /mnt/Storage_Pool/iocage/releases/12.2-RELEASE/root/usr/share/certs/blacklisted for certificates...
[2022/03/14 17:19:56] (INFO) iocage.callback():71 - Scanning /mnt/Storage_Pool/iocage/releases/12.2-RELEASE/root/usr/share/certs/trusted for certificates...
[2022/03/14 17:20:03] (INFO) iocage.callback():71 -  done.
[2022/03/14 17:20:16] (DEBUG) iocage.__start_jail__():248 - Grabbing IPv4 default route
[2022/03/14 17:20:16] (DEBUG) iocage.__start_jail__():250 - Default IPv4 Gateway: 10.50.1.1
[2022/03/14 17:20:16] (DEBUG) iocage.__start_jail__():253 - Grabbing IPv6 default route
[2022/03/14 17:20:16] (DEBUG) iocage.__start_jail__():255 - Default IPv6 Gateway: none
[2022/03/14 17:20:18] (DEBUG) iocage.start_network():1129 - Setting default route 10.50.1.1
[2022/03/14 17:20:23] (ERROR) middlewared.job.run():379 - Job <bound method accepts.<locals>.wrap.<locals>.nf of <middlewared.plugins.jail_freebsd.PluginService object at 0x819e3cc40>> failed
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_plugin.py", line 319, in fetch_plugin
    jaildir, _conf, repo_dir = self.__fetch_plugin_create__(props)
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_plugin.py", line 565, in __fetch_plugin_create__
    iocage_lib.ioc_create.IOCCreate(
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_create.py", line 101, in create_jail
    return self._create_jail(jail_uuid, location)
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_create.py", line 660, in _create_jail
    iocage_lib.ioc_start.IOCStart(jail_uuid, location,
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_start.py", line 87, in __init__
    raise e
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_start.py", line 84, in __init__
    self.__start_jail__()
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_start.py", line 755, in __start_jail__
    iocage_lib.ioc_common.logit({
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_common.py", line 107, in logit
    callback(content, exception)
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_common.py", line 80, in callback
    raise callback_exception(message)
RuntimeError:
Stopped clamav1 due to VNET failure
  File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run
    await self.future
  File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 405, in __run_body
    rv = await self.middleware.run_in_thread(self.method, *([self] + args))
  File "/usr/local/lib/python3.9/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
    return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
  File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 979, in nf
    return f(*args, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/jail_freebsd.py", line 296, in do_create
    ioc.IOCage(callback=progress_callback, silent=False).fetch(**{
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/iocage.py", line 1072, in fetch
    plugin_obj.fetch_plugin(props, 0, accept)
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/ioc_plugin.py", line 342, in fetch_plugin
RuntimeError: clamav1 had a failure
Exception: RuntimeError Message:
Partial plugin destroyed#
highlow
Hello Community,
raise e
RuntimeError:
await self.future
root@INDTCOBSDCAP01[/var/log]#
Running Trunas 12.0.U8
A VNET is the virtual network created for your jail so it can appear on the network as an independent machine.
If that fails for any reason, your jail has no network and therefore can't do what it's there for, hence stopping at that point.
Is the default gateway (set in Network | Global Configuration) really 10.50.1.1? (and is that the right address for your network's router?)
Also, what's your hardware setup? That may be important in giving some clues on the failure's cause.
jgreco
Resident Grinch
Please don't make forum members follow off-site links for your hardware setup. Also, that page is filled with lots of noise, and leaves a lot of ambiguity about what you're actually running.
