danton.bryans
- Sep 15, 2015
Posted to the Freenas subreddit, but crossposting to here to see if anyone has ideas. TIA
FreeNAS-9.3-STABLE-201509022158 installed and running. Groups and users added. Five datasets, all CIFS browseable, and all set to Windows permissions. Wheel is owner group, and my administration account is in wheel. I've been able to add/remove permissions for each shared dataset just fine (adding the other groups, removing Everyone).
I want to configure specific subfolder permissions on the user shares CIFS share (where each user has personal space). I would rather not have to create individual datasets for each individual user. But, when I go to remove the inherited permissions from the subfolder, it throws all sorts of errors.
When I try to just remove all the inherited permissions, I get: "An error occurred while applying security information to: ... The parameter is incorrect." This happens on every file, so you can only cancel out of it.
When I try to Add the inherited as explicit local permissions, it appears to run through but the inheritance check remains and I still can't remove the other shares.
Additionally, if I try to add the explicit user or group (Add->type in object name (e.g., User1 or User1Group, both of which exist and I can map from the main share), I get: "An object (User, Group, or Built-in security principal) with the following name cannot be found: "User1". Check the selected object types and locations for accuracy and ensure that you have types the object name correctly, or remove the object from the selection." I've checked capitalization, spelling, etc. and restarted the server two just for giggles.
Thoughts?
Thoughts?
