I'm using FreeNAS-9.10-STABLE-201605021851
I'm using datasets with Windows style permission, set from the FreeNAS GUI.
Then I'm using CIFS shares to share my stuff amongst Windows 7 and Windows 10 computers.
I've been reading around the documentation and the forum and I understand that the generally recommended wait to tweak the permissions is using one of the client computer to connect to the shares and tweak the permissions from the Windows Explorer security tab.
That part, I did, and it worked very well... All my shares have proper permissions.
But within some shares, I want some sub folders to have specific permissions.
I used to do that really easy with my good ol' Linux server, using SAMBA server and configuration file, I'd play with the UNIX permissions of the subfolders to give them specific restrictions.
For example if a share allows access to groups A, B and C.
I might like to set the permissions for a specific subfolder to group A only, or even to a specific User X.
When I try to do that, I get a weird message saying something about that folder having inherited permission from parent.
I'm trying to figure out how to fix that without messing everything up but I can't figure it out.
Thanks!
Thanks!
