Hi and thanks for another release of FreeNAS.
In short, in what fashion should windows shares be mounted in FreeNAS?
1) I am familiar with nano /etc/fstab with format as follows (which does not work as I get some error)
- \\windows.machines\sharename <tab>/mnt/mountpointname <tab>cifs <tab>username=whatever,password=whatever 0 <tab>0
2) I also tried mounting in the same fashion as described in the /etc/fstab file (less '/' etc) with no luck.
3) I am able to mount windows share as follows (but this obviously does not provide a permanent mount and is gone with reboot: mount_smbfs -I 1.2.3.4 //username@nasserver/share /path/to/local/mnt
4) NOW, while successfully mounted a windows share, I navigate to the share and can do a list in the dir, seeing all the files, BUT, with FreeNAS version: FreeNAS™ 8.0-RELEASE, when I go to CIFS and want to add teh windows (mount point) it just shows '-----' So in other words there is no drop down arrow.
5) Should I mount in a specific dir for the mount to appear in the web GUI?
Setup: vmware workstation 7, disc size:8Gb, memory size: 512Mb, Bridged eth0, etc...
Any assistance would be great.
Thanks to the developers.[/B]
