Chroot and SFTP
jmcvay
So I've been getting my feet wet with FreeNAS over the past few days and made the discovery today that changes to /etc are not persistent through reboots. divine in the FreeNAS irc informed me that in order for the changes to stick I would need to make them in /conf/base/etc. Then it took me awhile to figure out that I needed to mount the read-only file system. So I've got my /conf/base/etc/ssh/sshd_config file backed up and modified to my liking, but now I'm unable to login as a user of the group that is chrooted. I also noticed that the /etc/ssh/sshd_config file didn't change after I altered the one in /conf/base/ and rebooted.
What type of behavior should I expect from /etc/ssh/sshd_config?
What are some reasons I wouldn't be able to connect?
Changes in red
#	$OpenBSD: sshd_config,v 1.80 2008/07/02 02:24:18 djm Exp $
#	$FreeBSD: src/crypto/openssh/sshd_config,v 1.48 2008/08/01 02:48:36 des Exp $
# This is the sshd server system-wide configuration file.  See
# sshd_config(5) for more information.
# This sshd was compiled with PATH=/usr/bin:/bin:/usr/sbin:/sbin
# The strategy used for options in the default sshd_config shipped with
# OpenSSH is to specify options with their default value where
# possible, but leave them commented.  Uncommented options change a
# default value.
# Note that some of FreeBSD's defaults differ from OpenBSD's, and
# FreeBSD has a few additional options.
#VersionAddendum FreeBSD-20080801
#Port 22
#Protocol 2
#AddressFamily any
#ListenAddress 0.0.0.0
#ListenAddress ::
# Disable legacy (protocol version 1) support in the server for new
# installations. In future the default will change to require explicit
# activation of protocol 1
Protocol 2
# HostKey for protocol version 1
#HostKey /etc/ssh/ssh_host_key
# HostKeys for protocol version 2
#HostKey /etc/ssh/ssh_host_rsa_key
#HostKey /etc/ssh/ssh_host_dsa_key
# Lifetime and size of ephemeral version 1 server key
#KeyRegenerationInterval 1h
#ServerKeyBits 1024
# Logging
# obsoletes QuietMode and FascistLogging
#SyslogFacility AUTH
#LogLevel INFO
# Authentication:
#LoginGraceTime 2m
PermitRootLogin yes
#StrictModes yes
#MaxAuthTries 6
#MaxSessions 10
#RSAAuthentication yes
#PubkeyAuthentication yes
#AuthorizedKeysFile	.ssh/authorized_keys
# For this to work you will also need host keys in /etc/ssh/ssh_known_hosts
#RhostsRSAAuthentication no
# similar for protocol version 2
#HostbasedAuthentication no
# Change to yes if you don't trust ~/.ssh/known_hosts for
# RhostsRSAAuthentication and HostbasedAuthentication
#IgnoreUserKnownHosts no
# Don't read the user's ~/.rhosts and ~/.shosts files
#IgnoreRhosts yes
# Change to yes to enable built-in password authentication.
PasswordAuthentication yes
PermitEmptyPasswords yes
# Change to no to disable PAM authentication
ChallengeResponseAuthentication no
# Kerberos options
#KerberosAuthentication no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
#KerberosGetAFSToken no
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
# Set this to 'no' to disable PAM authentication, account processing,
# and session processing. If this is enabled, PAM authentication will
# be allowed through the ChallengeResponseAuthentication and
# PasswordAuthentication.  Depending on your PAM configuration,
# PAM authentication via ChallengeResponseAuthentication may bypass
# the setting of "PermitRootLogin without-password".
# If you just want the PAM account and session checks to run without
# PAM authentication, then enable this but set PasswordAuthentication
# and ChallengeResponseAuthentication to 'no'.
#UsePAM yes
#AllowAgentForwarding yes
#AllowTcpForwarding yes
#GatewayPorts no
#X11Forwarding yes
#X11DisplayOffset 10
#X11UseLocalhost yes
#PrintMotd yes
#PrintLastLog yes
#TCPKeepAlive yes
#UseLogin no
#UsePrivilegeSeparation yes
#PermitUserEnvironment no
#Compression delayed
#ClientAliveInterval 0
#ClientAliveCountMax 3
#UseDNS yes
#PidFile /var/run/sshd.pid
#MaxStartups 10
#PermitTunnel no
#ChrootDirectory none
# no default banner path
#Banner none
# override default of no subsystems
Subsystem	sftp	internal-sftp
# Example of overriding settings on a per-user basis
#Match User anoncvs
#	X11Forwarding no
#	AllowTcpForwarding no
#	ForceCommand cvs server
Match Group sftp
     ChrootDirectory %h
     ForceCommand internal-sftp
skh
I am currently having the same issue.
Steps:
1. mount -uw /
2. Edit /conf/base/etc/ssh/sshd_config for SFTP Jails
3. mount -ur /
4. reboot
Upon reboot, /conf/base/etc/ssh/sshd_config still has the changes however /etc/ssh/sshd_config is unchanged.
It has been 4 days since jmcvay's original post. Can anyone shine some light on this issue?
Thanks
Note: I have tried editing /conf/base/etc/fstab and the changes were reflected in /etc/fstab after reboot.
