Wronglebowski
- Mar 12, 2021
Hello all, I've got a degraded array I'm trying to sort our and I'm not sure how to proceed. I had a controller failure which caused a bunch of write errors that resulted in Checksum Errors. I've done a ton of Scrubs but I can't figure out what files are actually bad. This is what my status looks like.
Is there any way to determine what files <0x0> are referencing? Is there a way to tell TrueNAS to just blow away all checksum failed data?
root@truenas[~]# zpool status -v Starter pool: Starter state: DEGRADED status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A scan: scrub repaired 0B in 1 days 06:17:25 with 9 errors on Thu Mar 18 06:39:24 2021 remove: Removal of vdev 10 copied 671G in 1h6m, completed on Tue Mar 16 00:09:54 2021 15.6M memory used for removed device mappings config: NAME STATE READ WRITE CKSUM Starter DEGRADED 0 0 0 mirror-1 ONLINE 0 0 0 gptid/f8169c3d-521c-11eb-9d3b-001b2141b43f ONLINE 0 0 0 gptid/f826d7f5-521c-11eb-9d3b-001b2141b43f ONLINE 0 0 0 mirror-4 ONLINE 0 0 0 gptid/34adb076-53b0-11eb-9200-001b2141b43f ONLINE 0 0 0 gptid/34eb5a8a-53b0-11eb-9200-001b2141b43f ONLINE 0 0 0 mirror-5 ONLINE 0 0 0 gptid/34c609a4-53b0-11eb-9200-001b2141b43f ONLINE 0 0 0 gptid/352ff4be-53b0-11eb-9200-001b2141b43f ONLINE 0 0 0 mirror-7 ONLINE 0 0 0 gptid/3464dfdf-5940-11eb-9200-001b2141b43f ONLINE 0 0 0 gptid/34753e28-5940-11eb-9200-001b2141b43f ONLINE 0 0 0 mirror-8 DEGRADED 0 0 0 gptid/17dd1ce9-5d92-11eb-bfca-001b2141b43f DEGRADED 0 0 580 too many errors gptid/17f51e42-5d92-11eb-bfca-001b2141b43f DEGRADED 0 0 580 too many errors mirror-9 DEGRADED 0 0 0 gptid/bee72909-7ed3-11eb-a488-001b2141b43f DEGRADED 0 0 580 too many errors gptid/bf3c27b7-7ed3-11eb-a488-001b2141b43f DEGRADED 0 0 580 too many errors mirror-11 ONLINE 0 0 0 gptid/57402eaa-8660-11eb-808a-001b2141b43f ONLINE 0 0 0 gptid/575166f1-8660-11eb-808a-001b2141b43f ONLINE 0 0 0 logs gptid/f70b6e8c-521c-11eb-9d3b-001b2141b43f ONLINE 0 0 0 cache gptid/f64a55d8-521c-11eb-9d3b-001b2141b43f ONLINE 0 0 0 errors: Permanent errors have been detected in the following files: Starter:<0x0>
