Checksum Errors not going away
Miniwehats
So I have been getting a few checksum errors on a drive, about 4 - 20 that pop up every few days after clearing them and scrubbing. I decided to replace the drive with a new drive and that drive is also doing the same thing, I replaced the cable just the other night and still have the same checksum errors popping up. I ran a long SMART test on the drive and it passed....
[root@freenas] ~# smartctl -a /dev/ada2
smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p4 amd64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
Model Family:    Seagate Barracuda Green (Adv. Format)
Device Model:    ST2000DL003-9VT166
Serial Number:    5YD7BNE3
LU WWN Device Id: 5 000c50 0453eecc9
Firmware Version: CC3C
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
Sector Sizes:    512 bytes logical, 4096 bytes physical
ATA Version is:  8
ATA Standard is:  ATA-8-ACS revision 4
Local Time is:    Fri Aug  9 10:58:17 2013 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
Self-test execution status:      (  0) The previous self-test routine completed
                                        been run.
data collection:                (  623) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (  1) minutes.
Extended self-test routine
recommended polling time:        ( 341) minutes.
Conveyance self-test routine
recommended polling time:        (  2) minutes.
SCT capabilities:              (0x30b7) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAG    VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate    0x000f  111  099  006    Pre-fail  Always      -      31001712
  3 Spin_Up_Time            0x0003  092  092  000    Pre-fail  Always      -      0
  4 Start_Stop_Count        0x0032  100  100  020    Old_age  Always      -      26
  5 Reallocated_Sector_Ct  0x0033  100  100  036    Pre-fail  Always      -      0
  7 Seek_Error_Rate        0x000f  069  060  030    Pre-fail  Always      -      17214353154
  9 Power_On_Hours          0x0032  099  099  000    Old_age  Always      -      1582
10 Spin_Retry_Count        0x0013  100  100  097    Pre-fail  Always      -      0
12 Power_Cycle_Count      0x0032  100  100  020    Old_age  Always      -      33
183 Runtime_Bad_Block      0x0032  100  100  000    Old_age  Always      -      0
184 End-to-End_Error        0x0032  100  100  099    Old_age  Always      -      0
187 Reported_Uncorrect      0x0032  100  100  000    Old_age  Always      -      0
188 Command_Timeout        0x0032  100  096  000    Old_age  Always      -      8
189 High_Fly_Writes        0x003a  100  100  000    Old_age  Always      -      0
190 Airflow_Temperature_Cel 0x0022  067  064  045    Old_age  Always      -      33 (Min/Max 29/34)
191 G-Sense_Error_Rate      0x0032  100  100  000    Old_age  Always      -      0
192 Power-Off_Retract_Count 0x0032  100  100  000    Old_age  Always      -      16
193 Load_Cycle_Count        0x0032  100  100  000    Old_age  Always      -      33
194 Temperature_Celsius    0x0022  033  040  000    Old_age  Always      -      33 (0 15 0 0 0)
195 Hardware_ECC_Recovered  0x001a  027  009  000    Old_age  Always      -      31001712
197 Current_Pending_Sector  0x0012  100  100  000    Old_age  Always      -      0
198 Offline_Uncorrectable  0x0010  100  100  000    Old_age  Offline      -      0
199 UDMA_CRC_Error_Count    0x003e  200  200  000    Old_age  Always      -      0
240 Head_Flying_Hours      0x0000  100  253  000    Old_age  Offline      -      50607599650282
241 Total_LBAs_Written      0x0000  100  253  000    Old_age  Offline      -      2894833539
242 Total_LBAs_Read        0x0000  100  253  000    Old_age  Offline      -      2744958798
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error      00%      1582        -
# 2  Short offline      Completed without error      00%      166        -
# 3  Short offline      Completed without error      00%      165        -
# 4  Short offline      Completed without error      00%      164        -
# 5  Short offline      Completed without error      00%      153        -
# 6  Short offline      Completed without error      00%      109        -
# 7  Short offline      Completed without error      00%      108        -
# 8  Short offline      Completed without error      00%      107        -
# 9  Short offline      Completed without error      00%      106        -
#10  Short offline      Completed without error      00%      105        -
#11  Short offline      Completed without error      00%      103        -
#12  Short offline      Completed without error      00%      102        -
#13  Short offline      Completed without error      00%      101        -
#14  Short offline      Completed without error      00%      100        -
#15  Short offline      Completed without error      00%        99        -
#16  Short offline      Completed without error      00%        99        -
#17  Short offline      Completed without error      00%        98        -
#18  Short offline      Completed without error      00%        98        -
#19  Short offline      Completed without error      00%        97        -
#20  Short offline      Completed without error      00%        97        -
#21  Short offline      Completed without error      00%        97        -
I am not familiar with most of this data and cannot see anything really that stands out to me. I currently have 8 ports on my mobo filled so my only option is swapping around the ports and see if a different drive starts to do it on that port. Can you change drives around like that in a raid like this? Of course the NAS would be off...
[root@freenas] ~# zpool status Vol0
  pool: Vol0
state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
        attempt was made to correct the error.  Applications are unaffected.
  see: http://www.sun.com/msg/ZFS-8000-9P
  scan: scrub repaired 0 in 0h2m with 0 errors on Wed Aug  7 16:03:48 2013
        NAME                                            STATE    READ WRITE CKSUM
        Vol0                                            ONLINE      0    0    0
          raidz1-0                                      ONLINE      0    0    0
            gptid/338243b8-e7fc-11e1-8afc-00045fb309e8  ONLINE      0    0    0
            gptid/33c3355c-e7fc-11e1-8afc-00045fb309e8  ONLINE      0    0    0
            gptid/0994507b-fe52-11e2-b869-bc5ff4365648  ONLINE      0    0    23
            gptid/9ebf2708-5b6d-11e2-9efd-bc5ff4365648  ONLINE      0    0    0
          raidz1-1                                      ONLINE      0    0    0
            gptid/263683e3-5ab5-11e2-a20c-bc5ff4365648  ONLINE      0    0    0
            gptid/2d20175a-5d3a-11e2-952a-bc5ff4365648  ONLINE      0    0    0
            gptid/ee1160fe-5c7e-11e2-a059-bc5ff4365648  ONLINE      0    0    0
            gptid/52e8cd24-e7fc-11e1-8afc-00045fb309e8  ONLINE      0    0    0
Any help would be great! And I think I have a PCI sata controller somewhere around... its slower than my onboard but I think I could use it to test with.
paleoN
To recap, this is a new drive and a new SATA cable yet you are still seeing errors. The SATA port on the motherboard is the same and the PSU is the same.
This should be zero, 188 Command_Timeout 0x0032 100 096 000 Old_age Always - 8. Though still fairly low, this is another sign there is a problem.
Yes, you can swap SATA ports around. Just make sure to keep straight which are which.
I would just swap the ports, but this is another option if the controller works.
Miniwehats
To clarify yes, new drive. I believe it could be a refurb sent back to be though.... I tested in another port and the error follows the drive. My next option is to switch the sata power connection on the drive and see if it continues to follow the drive. If so then I guess I just happen to have bad luck and both drives doing chksum errors.
Didnt post my setup before... all about a year old now.
Corsiar 650TX PSU
ASRock A75 Extreme 6 Mobo
AMD A4 APU
16gig DDR3 2x 8GB Gskill 1600
8x 2tb/1.5tb Segate/Samsung drives. (yes I know im loosing space, slowly working on phasing out the 2x 1.5 TBs I have left in the aggr.)
Intel Gbic NIC
Miniwehats
I also grabbed the old drive that I replaced, I was about to RMA it but didnt send it because the replacement drive started giving errors to. Every test I throw at this drive passes just fine. So I am assuming its something with my setup :(
Also thoughts on torrenting to the NAS? I heard it was not recommended because massive reads and writes but its not like im running a seed box. Just torrent stuff every so often, TV shows and what not. I could torrent to a drive in my server pc and then move the stuff to the NAS its just annoying that way.
